Hello,
(Still) in the journey towards the optimal set up in my untreated a symmetrical room... Now facing the following dilemma.
Looking at integration of Lt & Right speakers, I face notable dips in the low end. Analyzing the source led to the understanding that it originates from local phase misalignment between Lt & Rt speakers that drive cancellations (probably not a surprise in an untreated room). Trying to relief that I designed a light cascade of AP compensation filters and applied it on the left filter.
The overall integration with those filters seems to improve the integration in the wide sense, but lead to the following observation\dilemma.
1- When looking at the phases of Lt (wo\filter) and Rt signals with FDW <5 (means very close to a direct sound) & FDW>=6 (more reflections + modes):
* FDW < 5 phase matching is perfect,
* FDW >=6 there is a built up gap in the phases (that lead to the Lt-Rt poor frequency image.
2- When looking at the phases of Lt (w\filter) and Rt signals with FDW <5 (means very close to a direct sound) & FDW>=6 (more reflections + modes):
* FDW < 5 phase matching shows cancelation in the integrated Lt + Rt response
* FDW >=6 overall Lt & Rt look fairly aligned, which lead to improved integration in the low end.
Knowing the sensitivity of our ears to the early 80msec period of sound arrival and its importance to imaging (hence smaller FDW) - may lead to the direction where optimizing phase should be based on low FDW ;
On the other hand, our lack of ability to localize bass at the range being focused at (<100Hz) and the nice integration at wide range of FDW >=6 may hint to optimize phase based on this setup.
I will be glad to get you - experts & experience - perspective on that.
(attached also the REW measurements in case someone is looking to play with the raw materials)
Many thanks!
Many thanks!
