- Joined
- Oct 25, 2019
- Messages
- 11,112
- Likes
- 14,776
Seems not. Just the non pro regular 'hifi' version.Are these avaliable anymore? Seems like they've been sold out for a long time now.
Hi guys, first post here. This toy looks great but unfortunately, it's impossible to find it new anywhere. Any other, similarly sized, adapters on par with it?
Nope. Then you are in the area of the $100 bt dongles. Like qudelix 5k reviewed on here (with eq) or fiio btr 5(no eq)Thanks! And would there be any of these dongles connecting just through Bluetooth instead of usb type C?
This sucka? (like I say, the naming is a nightmare. Lots of different sonata.I bought the Tempotec
I would like to buy the non pro version on amazon.it, I would use it via android -Tidal Hifi-UAPP, I have 50 ohm headphones
do you think it can also be connected to the amplifier to drive passive speakers? pity it's not MQA
thanks, for your kind replyUAPP with an MQA add on will decode Tidal MQA then send to the Meizu at 24 bit 88.2khz or 96 khz (ie the core decode)
Yes you can connect to an amp via 3.5mm- RCA cable.
https://www.aliexpress.com/item/100...&terminal_id=e1ef815efc2645b8bd1a0abac6865502Where? Give me the link ,please
recognises headset with mic, no need to install any firmwares i believe, it's a win already, and +10 miliwatts, same compact, lol. i ordered, whatevs, i wanna see if it's stuttering on laptop like Sonata HD 1, when cpu usage is 80-90%
You can use whatever DAC+ADC combination you want in Windows 10. You just have to select them in the Sound Control Panel.Got the Sonada HD II USB Dac, don't see much of the difference in sound over HD I, but I am ok with the sound, I know there is something better, but compact size suggests me to keep it. Good news, on PC or laptop it doesn't crackle or doesn't clip when CPU is loaded with apps @60-71% and music player is playing at the same time, unlike Sonada HD I! Also you cannot use USB Mic, once Sonata is plugged into PC, expects a headset, I assume, not sure yet if internal mic is being enabled when using Dac on laptop
I did, it was setup for usb mic, and headphones set for tempotec sonata , but nobody heard me in gamesYou can use whatever DAC+ADC combination you want in Windows 10. You just have to select them in the Sound Control Panel.
L7 has: https://www.l7audiolab.com/f/ugreen-usb-dac/Anyone try this one? Look like a clone of Meizu Hifi Pro, it's from uGreen
https://detail.tmall.com/item.htm?s...13448049&ns=1&abbucket=16&skuId=4716842879281
Meizu for reference: https://www.l7audiolab.com/f/meizu-pro-解码耳放/
