staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,010
- Likes
- 12,851
The Windows Direct Sound up/downsampler is not very good at its job. I recommend you set your DAC in the sound control panel to the sample rate that you consume most of the time, to avoid sample rate conversion as best as possible. Bit depth should be set to the highest possible value.I recently got the meizu master hifi, I use it on the pc. Which sampling rate do you recommend? 32bit 384? 24/96? Putting the maximum available (32/384) are there problems with audio interruptions?
If you're listening to MP3s, FLACs, WAVs, use a player with wasapi output to bypass the direct sound mixer and to always play at the native sample rate of your files.
