Nice to see that graph. I've hear people say these speakers with the 035ti tweeter go bad and sound harsh because damping material in the tweeter disintegrates. But this measurement doesn't show any obvious problem in the treble.Getting into vintage territory, we have the JBL L100T 3-way with ported 12" and titanium dome tweeter. My uncle was the orignal owner of this pair from the mid 1980's.
View attachment 360217 View attachment 360218
A mighty undertaking, I must say. Good work!I thought this group would be interested in how some vintage speakers compare to each other under the same measuring conditions. I have a collection of vintage speakers and simple measuring setup. No Klippel machine for me! I measured the frequency response of each speaker with:
All of the measurement suffer from a floor bounce dip at ~80-90hz depending on the height of the woofer and mic. Sorry about that.
- Laptop PC with Creative soundcard
- REW software
- Dayton UMM-6 microphone, with calibration loaded in REW
- Random Denon amplifier
- 1 meter distance, on the tweeter axis
- 20x24 garage with hard floor and 9.5' ceiling
- Small amount of damping on the floor
Here's the setup.
Here's the collection.
Here's all the graphs together. I'll post each frequency response curve separately.
Would be nice if you could explain how you measure the bass (incl processing)Thank you for doing all this and sharing! I'm always very curious about the performance of vintage speakers.
Because you have plenty of space around the speakers and measured at 1m, you should actually be able to get a decently high resolution gated (AKA quasi-anechoic) measurements for upper frequencies using the data you've already captured! How clean the data is depends on how much the cabinet the speakers are rested on affects things, but since you pushed the speakers most of the way toward the front, it should not be a big deal.
In any case, the measurements wouldn't change much since the speakers are already fairly far from the walls, but could be interesting to investigate.
If you are willing to share all the measurements in a REW file, I can go ahead and convert these into gated measurements (although it's not complicated).
Also, I don't at all intend for you to do any more work, but if there any specific speakers you want to measure the bass for quasi-anechoically I can help you out with that too. The measurements process is fairly simple to do, and basically just involves placing the microphone very close to the woofers and ports. You wouldn't have to position the speakers in any special type of way. I could do then do the processing.
Wouldn't be *pristine* without a bit more care, but should "close enough".
(I apologize if you already know how to do all this, just offering the few skills I have in this space )
I don't quite understand...Thanks for publishign this.
Quite some work...
Looking at this one is interesting, IMO, since it shows immediately common "incidents" which are more likely due to room/position.
Like the peaks at 55Hz, 70Hz and 95Hz and the consequent dip around 85Hz.
This could be even more obvious if the plot levels were aligned on an average on, say, 1kHz-2kHz, as an example.
Yes basically these are in a given room with the speaker placed at a given location responses with the mic placed at 1m, on axis, at tweeter height, etc, etc...I don't quite understand...
Those measurements are not being corrected by
the analizer?
If so, are we seeing loudspeaker performance or
room responsiveness?
Thank you.
Sorry, did not realize the way work was done.Yes basically these are a given room responses at 1m, on axis, at tweeter height, etc, etc...
Yes i have spent hundreds of hours doing similar job, and so have learnt that are totally useless...Sorry, did not realize the way work was done.
I thought it worked the usual system we usually see here when Amir shows results.
I understand now.
Sorry...Thank you.
Question is if what you see is what you hear?Thanks for all the great measurements.
I can't be alone in thinking that there's not as much as improvement from old to new as you might anticipate.
Well, I think we can see the performance each offers when placed there.Then why do measurements at all?
You need measurements to get an insight. The picture in itself is irrelevant if there is no way to understand what can be learnt from It. Or the cues It gives are misleading.Then why do measurements at all?
Are these measurement really useful at all?
Perfect as an educational example to show how room acoustics work regardless of which speaker is used. I am thinking specifically of the area around 80-90 Hz.Then why do measurements at all?
Yes but what is true at 1m is no longer the same at 2m, on axis and 30° off, etc...Perfect as an educational example to show how room acoustics work regardless of which speaker is used. I am thinking specifically of the area around 80-90 Hz.
And if you move the coach or add a jar withYes but what is true at 1m is no longer the same at 2m, on axis and 30° off, etc...
