Mcintosh: the looks
Chrispy
PNW
Gear aesthetics mean little to me generally, and the McIntosh lights/meters mean little to me. The design isn't remarkable IMO. Then again I don't fondly gaze upon things like amps/receivers....I just use them. The resale value/look does appeal to many, tho.
mhardy6647
McIntosh is a funny brand -- it's sort of the Checker Marathon of hifi equipment, I'd opine.
The stuff is perfectly OK, but it doesn't really manifest anything like the level of quality or performance that is ascribed to it by its rabid fan base.
(IMO, of course). And, as noted before, yes, I do own a few pieces of Mac equipment -- mostly because of the aforementioned resale value thing. :) Oh, and I do like many of the tuners they've produced over the years.
Dj7675
They should sound resonably transparent, the manufacturer specifies essentially flat FR, 122db SNR and -86dB THD for the MC462. And with 450W per channel it will be plenty powerful.
I too think that it looks rather ... tacky. However not necessarily in a bad way - not like some of the supposed "high-end" products with cheap, generic cases.
Instead it features some very detailed case work, but for me personally, less would be more in that regard.
Are you sure about the -86dB? Stereophile measured it and it appears to be a very good performer.
https://www.stereophile.com/content/mcintosh-laboratory-mc462-power-amplifier-measurements
Also, @Matias has assembled a very good list of measurements from all over. That thread is located here and the link to the spreadsheet is here. Relative to other amps it seems to be near the top it seems. They do make a few silly things for sure like their clock, but they are still making some very good performing amps.
3125b
Germany
Manufacturer specification is 0.005%, wich equals -86dB. I didn‘t make that up.
And sure enough, it‘s actually true near full power with a 4 ohm load, wich is kind of a worst case scenario, making the specification rather conservative. They could have claimed 0.00035% and it would have been true as a sort of best case scenario, wich I‘m sure some manufacturers do.
MediumRare
Chicago
They use that as a blanket on all their amps. The apples-to-apples number as Amir calculates it is generally much lower.
3125b
Germany
The real performance is remarkably good indeed and thanks for linking that spreadsheet, it‘s very interesting to see how some of the most expensive amps perform (or, well, don‘t).
MakeMineVinyl
Santa Fe, NM
MediumRare
Chicago
Nice! So the 8 ohm number the way Amir measures it is a little over 400 WPC at the elbow (516 WPC clipping) into 8 ohms and 0.0007% THD+N. However, @amirm reports SINAD at 5 WPC so the McIntosh would measure at .0008% (-102dB), which puts it among the top 4 power amplifiers ranked on ASR. Interesting that between 30 and 200 WPC into 8 ohms SINAD is at or below -106 dB.
MaxBuck
SoCal, Baby!
McIntosh equipment has always had the look, to me, of equipment that costs way too much for what one gets.
Wes
True now. Likely not true in the 1950s...
MakeMineVinyl
Santa Fe, NM
McIntosh is surprisingly low cost (relatively) compared to some of the 'ultra high end bling" brands, such as....
MRC01
Pacific Northwest
Regarding looks: I like equipment that is well built but function over form. High quality parts with solid build made to last for years if not decades, but nothing fancy or blingy. A look that says, "Tools, not toys". Like the electronic equipment I used to work with on Navy ships.
Some of the pictures posted above remind me of the gold toilets and firearms found in Saddam's palace. Beyond silly, just ridiculous.
MakeMineVinyl
Santa Fe, NM
R
rman9
I am thinking about putting up track focus lights to shine on the Mcintosh equipment, just like how they would do for a painting... Yes I'll do that.. maybe with a dimmer switch.. :)
