I just merged another thread that was another flavor of the same discussion.
When discussing the audibility of distortion, we have to keep in mind that the distortion products are not a separate signal. If they were, and as low as many amps are capable of, they would be easily masked. Distortion is different in that its a modifier. IOW it changes the sound of musical instruments by adding harmonics. Harmonics define that sound of a musical instrument, in case their role isn't clear... ask any luthier about that.
For the record, I did not say the ear is super-sensitive! To many things it is not. What I did say is that its keenly sensitive to the higher orders.
A 3rd harmonic in loudspeakers is well-known to mask higher ordered harmonics. I'd be interested in a study that shows that somehow this phenomena does not happen in amplifiers as well
Has a version of Distort been issued that allows one to model rising distortion with frequency? The author mentioned on this site that he had a version that could do that but didn't release it because the idea was 'too arcane' (paraphrasing). Since this is a common problem with most amplifiers employing feedback (which is most amplifiers in general) an audibility test that does not include this behavior is oranges and apples.
If you've not read it, Bruno Putzeys has a great article on feedback:
https://linearaudio.net/sites/linearaudio.net/files/volume1bp.pdf
If you read this article you'll see how important this aspect of distortion can be. We see that, as frequency rises, when the circuit meets its Gain Bandwidth Product limit, feedback decreases on a 6dB slope so distortion rises on a similar slope. As frequency continues to increase, its not uncommon for the distortion to rise at an even faster rate than that (because the feedback can fall off on an even faster rate depending on circuit variables).
If we take the example of 1KHz as a turnover point, we can see that at 7KHz the distortion can be quite a lot higher than the THD otherwise suggests! Our ears, as pointed out earlier, will assign a tonality to this and 7KHz is at the upper end of our ear's most sensitive range. In a nut shell if Distort does not model this you can't rely on the result.
If distortion rises with frequency, I think you'll find that the THD figure that an amplifier might have in practice isn't really accurate. IMO it really isn't a useful spec.
Compressor/expanders use a RMS signal to control a multipler and need attack and release times. You can use asome tubes as the multipler (variable mu) by changing the grid voltage, but making it input level and freq dependent on purpose needs extra circuitry (eq/rms detector) as do the attack release times which cause huge distortion if wrong. (too fast compression will amplitude modulate/flatten peaks, too slow causes pumping, both very audible). How does one do this in a simple SET amp on purpose?Consider the fact that a good variety of analog studio effects were designed well before DSP came on the scene, including compressors / expanders, including ones built on tubes. The idea that engineers couldn't figure out how to design specific, similar effects in amps on purpose is pretty strange.
I'm not saying they did that in this case, but it's way beyond possible to do so. Fancy analog compressor / expanders existed decades ago
Is it? I don't consider compression an "effect." It is a process. Maybe this is a semantic thing but no mastering engineers I know use that word unless they are referring to things like reverb, chorus, delay, etc...I guess you do not know a much of mastering process? It's nothing but effects.
As for me, I always clearly state that what I'm hearing is my personal impression; one is free to consider it or dismiss it as one sees fit.
Blind check?Not really but I am a cynic by nature. I also enjoy experimenting and tinkering (as a hobby I design and build my own amplifiers, loudspeakers, and guitar pedals for example). I try things and listen. Sometimes I am surprised by what I hear, often times I am not. I did not expect a change in power supply to make a noticeable audible difference because we shouldn't if everything is in clean DC. Maybe the wall wart I got wasn't great. Who knows. It's just one empirical observation (2 if you include my friend's P50).
Since I have 3 systems in my home, I have ordered 2 WiiM Pro Plus that are scheduled to arrive in India on September 15th and 30th (via 2 different friends). I will connect these 2 with the same linear power supply (I have 2 5V DC / 1A linear power supplies and can easily build a third) I have and check.
That, I don't know, I don't have any real electronics knowledge. But since the attack / release would be fixed in an amp, presumably it's a simpler circuit? Really no idea tho.How does one do this in a simple SET amp on purpose?
A tube compressor has at least twice the circuitry as a tube amp.
Time constants of amps should be very short compared to the signal. A very fast compression flattens the peaks (might be the cause of some of the huge distortion in lower freqs. in that amp). I just finished DIYing an IC compressor. The rms detector and multiplier came in a THAT IC ( its an updated DBX vca). Heres the rest of a compressor, including the control circuitry, which all compressors have (even if you cant adjust them) . Attack, decay, threshold, ratio, and gain are all there and all have audible effects.That, I don't know, I don't have any real electronics knowledge. But since the attack / release would be fixed in an amp, presumably it's a simpler circuit? Really no idea tho.
The effect may have just shown up by accident, I don't dispute that. The fact that it may be euphonic I guess, just a happy accident.
Topology plays a role in the kind of distortion the circuit will express.Compressor/expanders use a RMS signal to control a multipler and need attack and release times. You can use asome tubes as the multipler (variable mu) by changing the grid voltage, but making it input level and freq dependent on purpose needs extra circuitry (eq/rms detector) as do the attack release times which cause huge distortion if wrong. (too fast compression will amplitude modulate/flatten peaks, too slow causes pumping, both very audible). How does one do this in a simple SET amp on purpose?
Agree...The way I see it that Amp is a bad effects box with incosistant results depending on the music. You may call it lucky, but Im sure there's better ways to get euphonic distortion if you want it.
what we notice (perceptually) and recall (categorically) can't be considered as unweighted/verified data.
It's not just in audio, I think this applies to many spheres of life. There are people who believe what they want to believe, and there are people who want to be correct more than they want to believe something. I think it takes a lot of discipline to apply the latter POV in even one area of life, let alone all of them.
Some say it's butyric acid. That most North American chocolate was originally made with rancid milk, and that the manufacturers these days add butyric acid (giving the taste of vomit) on purpose. Either to get a longer shelf life, or because people demand the flavour. Other say that butyric acid is no longer found in North American chocolate, but it's just terrible quality in a number of other ways.
Either way, IMO, it give a funny link to the mechanisms of nostalgia and/or "burn-in" and how it defines our ideas of quality.
I wonder how many North Americans, who have lived in Belgium or Switzerland, still prefer their native variety of chocolate.
One of our German Au Pairs went on and on about how much better German candy was. Then her Dad sent her a care package of her favorite stuff and it was full of Mars and Cadbury products.
(I lived in Switzerland, you don't have to convince me there is better stuff than Hershey's, but the market is very global now).
Yes. I'd read about the rate of information in detail in the early 1990's. Much of the stuff known had been known for some time prior to that. As shown in that link of yours senses take in about 11 mbps. Interestingly 10 mbps of that is for vision. Wonder why we are more prone to be biased by what we see, and why tests of our senses need to be "blinded". All of this is filtered down so we can work at about 50 bps rates.Yup. This light read may be just enough to put things into perspective. I find it fascinating how brain is able to process so many bits of information from sensory input, also mechanisms which are acting subconsciously to filter the data, thus making life easier and perhaps more energy efficient (information processing requires energy). But there's also unconscious bias we always seem to develop due to so much data compression. Perception plays an essential role in our day to day lives, but your may differ from mine, so a moot point when it comes to objective evaluation if no proper controls are involved.
We lkie to tnhik taht the way we laren how to raed is one ltteer at a tmie but trehe is atcullay mcuh mroe hpapnenig bhenid the crtunias.
Adding effects to the mix is one thing but using a pre defined effects box to start your judgement of what to add is another thing to begin withI guess you do not know a much of mastering process? It's nothing but effects. Effect after effect, quite subtle though. Final touch. Emotion. Technically quite advanced of course, if you referring that.
Hearing from what? A headphone and speaker? A neutral one which is “not right” or a well designed by hearing phone or speaker? But the “well designed by hearing” one already add their effects so that they “sound right” in a neutral source, and further adding effects will throw off the balance…By hearing? You still have your senses, beside calculations? That is the biggest mistake by mixer or mastering engineer to trust just numbers and hope the best.
Yes, fascinating to consider sensory input, bandwidth and processing speed.
If we are ok with analogies to our silicon friends, I would not limit my conceptual model to foreground processing and necessary data compression, but also consider multiple threads and background processing. I think it's an oversimplification to divide conscious/unconscious with a hard boundary. We may have something more like a conscious/subconscious/unconscious continuum.
I expect we process conceptual thinking and kinesthetic awareness differently, for example, and we can certainly learn the latter as well as the former. With practice, we don't need to put the latter into mental words or even word-pictures (maybe we do with initial learning) so that data rate (or data transform) bottleneck isn't applicable. Kinesthetics may still be subject to direction/intention, just without mental language processing.
We can also practice cognitive therapies and expand the boundary of the conscious into the subconscious. Maybe similar with emotional intelligence, awareness of sense-perceptions and so on. Not my field specifically so I'll have to think about it some more.
You said earlier: However the fact remains the many people can hear differences between amp 'A' and amp 'B'. You state it as a fact. It is an unsupported fact.
