I suffer a lot with some headphones in that regard as I try to measure them. If I remember, I will point it out.There should also be a way to measure the level of sealing provided by the earpads... Some headphones are sensitive to that.
That is what I have done so far.Are headphones rated with or without EQ? I would suggest to use more clear categories.
Recommended
or
Recommended (only if you use EQ)
or
Not recommended (regardless of whether you use EQ or not)
Not at all. If it comes close to reference or sounds great as is, I will give it a recommendation on that basis and not even try EQ if not needed.Yes, I noted that on the HD800. But you also wrote that all headphones must be "EQued". That is confusing to me when it comes to the recommendation. Does it mean that recommendation "out-of-the box" is not an option?
I haven't had success in generating these filters in REW for headphones. Does anyone have a write-up on it?3. Have REW generate PEQ settings aiming for the Harman curve.
I recommend the Auto EQ project by Jaakko Pasanen. It is very well documented and a powerful tool for equalizing headphones. You can define a lot of variables, including filter settings and compensation curves.I haven't had success in generating these filters in REW for headphones. Does anyone have a write-up on it?
Please keep in mind that narrow positive gain notch filters can cause more audible problems than the increased distortion due to the higher power, one of the reasons why EQ cannot fully correct a flawed transducer:
-Positive notch causes ringing in time domain. This is more likely be audible above low frequencies and high Q-values.
From https://support.genelec.com/hc/en-u...-does-GLM-not-fix-dips-on-frequency-response-
I used to also use such extreme auto-EQ settings in REW but nowadays prefer more moderate manual filters which may not look from FR as nice but sound better to me, so can only recommend everyone testing several EQ strategies and chose the one that sounds best to him.
That is probably also the reason why a lot of HRIRs have such a bad reputation. They often do not subtract all the comb filters of the room and distortion of the playback/recording system. The sound can get really messy when you apply all that to your headphone.Please keep in mind that narrow positive gain notch filters can cause more audible problems than the increased distortion due to the higher power, one of the reasons why EQ cannot fully correct a flawed transducer:
This, especially because hearing resolution isn't as good as the current measurement rigs' resolution, thus oftentimes this one notch filter might contribute a lot of additional THD, yielding no real improvement to the perceived sound, since the resolution is lower anyways.That is probably also the reason why a lot of HRIRs have such a bad reputation. They often do not subtract all the comb filters of the room and distortion of the playback/recording system. The sound can get really messy when you apply all that to your headphone.
Both ODMs (companies that make headphones under branding for others) and manufacturers have contacted me privately. They don't want to comment in public though as you say.Regarding headphone measurements. I think it would be useful if we had input from someone who worked in headphone design. I am under the impression that many members here have experience in building loudspeakers and/or knowledge of the industry but are there any headphone engineers on ASR? Of course, I am aware that manufacturers are protecting their trade secrets and employees maybe cannot say much.
I don't think so. Problem is that your headphones will be different and so you are not hearing what I am hearing. I think the best ratification we can have is people taking the EQ settings if they have the same headphone, and apply them themselves. If the results are mostly positive, then we know it is working.Would you think that running tests comparing some "raw tracks", just EQ'd to the target curve with what was played & recorded back, could contribute anything of value?
