I like waveguide around the ribbon in post 1 versus post 13.
"The company has also redesigned the horn-like waveguide attached to the Folded Motion Tweeter, settling on the final version only after evaluating almost 50 design iterations with the goal of enhancing the consistency, dispersion, and output of the tweeter. The new waveguide is designed to ensure consistent performance across a wide range of listening positions while minimizing unwanted room reflections, according to MartinLogan. Waveguide-enhanced tweeter dispersion for the Motion Series is spec’d at 90° x 90° and 45° x 90° for the Motion XT Series."
That's a lot of R&D expense that will be passed on to the customers.
I'd like to see more of a smooth waveguide round over, but maybe the dispersion if the ribbon doesn't reflect badly where the waveguide breaks to the front baffle.
No way that tweeter does +/- 45 degrees vertical degree dispersion.
The xt b100 (6.5" 2-way) looks interesting at $800 each.
Bookshelf speaker
www.crutchfield.com
I don't see any mention of shorting rings, copper cap, just the basically fiberglass slurry cone..........
I'm sure we'll rip it apart having resonances coming out of the port or not enough stuffing, etc.
Especially compared to an emotiva b1+ or the less liked b2+.
Hopefully it is a good woofer/mid.
I'd read an opinion where he kept the polk r200 over the emotiva, mainly because, eventhough the tweeter in the emotiva was nice, the woofer is meh.
