An AMT is not a ribbon. Good ones typically have THD readings in line with a good dome.Or buy 1 from crutchfield.
Bigger tweet than emotiva.
Comes in wood, white, or black.
Steep competition at 800 each.
Pair of Polk m200 for $700, pair of emotiva t1+ (3 ways) for $900, pair of revel m16 for $1k, pair of (improved) klipsch rp600m ii, or on sale single revel m106 for $770.
Or even a single 6" golden ear brx for $950.
Some love ribbons, eventhough they can harmonicaly measure worse than domes.
I remember Zaph's measurements years ago.
maybe the micro detail outweighs the macro.
Thanks for the report. I'll be very interested to hear any further impressions you may have of the B100 tweeters, especially with respect to dialog intelligibility. I say that because my center speaker is the Polk LSiM706c, which has a similar ring radiator tweeter to that of the R200. I know it's supposed to be a good tweeter, with good dispersion, but the sound just doesn't seem that clear to me unless my ears are pretty much right in line with the tweeter. Dialog intelligibility is my top priority.My XT-B100's were delivered yesterday, I ordered from Best Buy and have 14 days to decide if I want to keep or return. I only sat in front of them for a song or two so no critical type listening yet. I did hook them up in my TV room and had YouTube music playing thru TV to Dac into amp half the day yesterday at loud volume while I was on the back patio putting together a new board for a dynakit st-70. So at the moment the Logans are on stands where my Polk R200's normally sit.
My personal initial impressions are that they look nice with a well made enclosure. I really like the one piece front baffle with the wave guide. My first AMT tweeter and this one has some size to it. They ML's are about a pound heavier than the Polks even though the Polks are about 2 inches deeper in size. I'd say the tweeter and high frequency's are what really stand out vs the R200, with more vertical and horizontal dispersion. Polks seem more balanced in low-mid low bass area, but I'll spend more time with the Logan's today to try and get a better feel for that assessment. Initially right out of the box I felt the Logans sounded a little shrill with heavy sibilance..but when I came back inside the house after a couple hours of them playing all of that went away. I'm not too sure about that rated spec of 93db sensitivity.
So that is just a quick little insight of what I thought/experienced. I am a big fan of the Polk R200, but I think the tweeter on the Logans made me perceive them as a little more refined sounding. The Logans cost ($1700) about 3x's the amount I paid for a new pair of R200's though ($575).
I think the tweeter on the Logan is the star of the show. It's definitely a little more lively than the Polk's ring. Although contrary to the data I seen on the R200's when I measured mine with Dirac on my Arcam SA30 my Polks had a good 3 to 4 db drop off after say 9 or 10khz. I've never had issues with intelligibility though.. actually after I got the polks I ditched my center channel and AVP all together and switched to 2.1 for TV and music in the living room. Phantom center has been working fine for me. I can say that even with only the limited amount of time with the Logan's voices seem a little crisper and cleaner when watching TV. I should be able to spend some time with the Logans tonight and tomorrow, give me a chance to find out what I don't and do like about them. I had to send my Arcam in due to issues with a channel so I'm not feeding the Logan's with the cleanest of power right now. I'm using an old B&K amp that I use to use with my AVP.Thanks for the report. I'll be very interested to hear any further impressions you may have of the B100 tweeters, especially with respect to dialog intelligibility. I say that because my center speaker is the Polk LSiM706c, which has a similar ring radiator tweeter to that of the R200. I know it's supposed to be a good tweeter, with good dispersion, but the sound just doesn't seem that clear to me unless my ears are pretty much right in line with the tweeter. Dialog intelligibility is my top priority.
Meticulously copied from Revel.Yes, they call it their Folded Motion Waveguide.
"After an extensive evaluation of nearly 50 design options, the Folded Motion® Waveguide profile was meticulously chosen to harmoniously align the tweeters output with the dispersion of the midrange drivers, enhancing the performance of our already incredible Gen2 Folded Motion® Tweeters. The Folded Motion® Waveguide helps blanket the listening area with evenly distributed detail and precision, ensuring an optimal experience for everyone. The waveguide also enhances the Controlled Dispersion output of the tweeter, offering generous coverage while minimizing unwanted room reflections."
ML-Motion Series
products.martinlogan.com
The vertical and horizontal sweet spot of this AMT tweeter may be small compared to other speakers but it is a little better than the Polk's. Well the horizontal on the Polk' isn't overly bad but if you sit up straight or especially stand you can hear the difference quite easily. If you want the full effect of that ring tweeter you really want to be ear level with it..but it still sounds good to me even if I wonder if to the side of the room. I personally don't need to be sitting down right in front of a speaker to enjoy it lol.Thank you for weighing in !!!!!!!!!!!!!!
I am worried more was spent on the cabinet than the speaker.
I was figuring the tweet would be the star.
Due to the vertical size of the tweet, I'd imagine vertical sweet spot would be small, I doubt the "waveguide" is doing anything vertically.
But width, I'm not sure it would have the horizontal dispersion for the highs to even see the waveguide.
But the waveguide can help move the tweeter physically back for a deeper reverse null for the crossover.
If it is a little weak in the midbass, I wonder if there is any baffle step in the crossover...................
The woofer cone looks fun, but I'd rather have shorting rings or copper cap on the pole piece in addition to the kevlar.
I saw where someone sent back his emotiva (with amt) saying (approximately), "yea the tweet is good, but the woofer is, meh."
I hope that is not the case on these.
But I do applaud ML for trying to do non panel speakers.
Seems a hard sell nowadays....................
