welwynnick
- Joined
- Dec 26, 2023
- Messages
- 625
- Likes
- 795
Single monoblick amplifier.Hi,
Is the Amazon price USD 599,— for a pair or for a single Monoblock?
thw
thw
Mono. For two channels double it.Hi,
thw
Is it possible to bridge 2 of these B200 amplifiers together?B200 is the basically an LA90 Discrete that's optimized for bridged configuration only. Gain structure and values are re-tuned for lower noise. PCB layout was tweaked a little to reduce magnetic field coupling in the chassis slightly for lower THD.
Do you see any problems?
Good point, perhaps finding the internal ground/0V and common that would be necessary as well.Yes - the amps are already bridged internally. The black terminals are not ground or 0V, they are already the inverse of the red terminals.
Connecting two driven terminals together might end very badly depending on how the internal ground/0V is referenced between the two amps.
No, that would defiantly cause a short circuit when you connected the two black terminals together. Remember you have inverted the input to the amps. That means the black of one amp is the invers of the black of the other amp. If the amps grounds are connected together - or just have a relatively low impedance between them - either via the power supplies, or via a connection you make, you are then shorting those inverted signals together.Good point, perhaps finding the internal ground/0V and common that would be necessary as well.
The B200 can not be bridged. See some posts before you. So there is no use to spend USD 2.400 to try to bridge them. A very expensive puff of smokeBridging 2 Pairs of B200 would cost you USD 2.400,—
What about Bridging two Topping LA 90 discrete?
It’s 280 absolute ultraclean watts at 4 Ohm - the ultraclean part of B200 ˋs (unbridged) watts may be 140 Watts.
And shenzenaudio has a special offer for the next 38 hours!!!
It would cost you just USD 1.406,— / pair.
TOPPING LA90 Discrete Speaker Amplifier
LA90 Discrete can be set up as a combined machine and can control its own volume. LA90D Discrete can be configured into a power amp without volume control. This is convenient especially for dual mono use. If you also require a headphone amplifer, it is recommended to use LA90 Discrete with A90...shenzhenaudio.com
Topping LA90 Discrete Amplifier Review
This is a review and detailed measurements of the Topping LA90 Discrete balanced stereo amplifier. It was sent to me by the company and costs US $799. The case is the same as the IC-based Topping LA90 which is fine with me given its high quality look and feel. The power switch doubles as input...www.audiosciencereview.com
Yours,
Thorsten
The B200 can not be bridged. See some posts before you. So there is no use to spend USD 2.400 to try to bridge them. A very expensive puff of smoke.
Its an idea, I will looking to it but not sure there would be a doubling of power output if they were bridged?Bridging 2 Pairs of B200 would cost you USD 2.400,—
I love the Purifi speakers but I am not a fan of class D, and if I went that route I would buy the bare board + PSU and stick it in a case myself and save a ton of money.400w @ 4 ohm, just get something like this Audiophonics
AUDIOPHONICS HPA-S400ET Power Amplifier Class D Stereo Purifi 1ET400A 2x400W 4 Ohm - Audiophonics
Class D stereo power amplifier based on two PURIFI 1ET400A modules and a HYPEX SMPS1200A400 power supply.www.audiophonics.fr
The B200 is already (essentially) a bridged LA90 with the volume pot removed. But at a lower price.I will looking to it but not sure there would be a doubling of power output if they were bridged?
Yes, also good choice, but if you look at the LA90 discrete Test of @amirm you will see, it nicely quadruples the power if bridged (so clean 279 Watts instead of clean 70 Watts) - it is the theoretical maximum of what you can win because of bridging! The LA90 discrete is a very, very good amp! But who knows about its reliability?Its an idea, I will looking to it but not sure there would be a doubling of power output if they were bridged?
I wish Topping would produce something more powerful than an amp that struggles to get 200w because the distortion is going to be high at that power.
Something like a B300 would be nice, or else I'll buy the Outlaw 2220 mono blocks which has 300w and a built in PSU and is cheaper anyway.
First - why the upgrade? What are you expecting to improve? Because unless you are needing more power than the PA7 can deliver, or some other feature, then you are unlikely to get a benefit.Hello! I have a pair of kef r3 meta paired with topping pa7, i m thinking to upgrade my amp to this b200 class ab or hypex nilai class d and i don't know wich one to choose. Some help will be nice! Thanks
I m listening on moderate volume levels, but i m thinking about better sound, like fuller midrange, fuller bass, bigger soundstage etc. I making a mistake? Pa7 sounds good, very clean, that s why i m asking if it s worth upgrading or notFirst - why the upgrade? What are you expecting to improve? Because unless you are needing more power than the PA7 can deliver, or some other feature, then you are unlikely to get a benefit.
