…and that’s a bad thing.
Look at the other graphs further down in Amir’s review: it behaves like a number of point sources interfering with each other.
Look, you should stop referring to this speaker as a line source. The only thing it behaves “pretty much like” is a
truncated line source, aka coitus interruptus linesourcicus. A
true line source isn’t intended to present the vertical dispersion that this thing does. A true line source would behave more like this at 4m:
Ref: Keele and Button,
Ground-Plane Constant Beamwidth Transducer (CBT) Loudspeaker Circular-Arc Line Arrays, 2005
If you care to try and transfer from Amir’s LRS 4m vertical directivity plot to the above plot, it will get real ugly real fast. Not good.
People thinking “line source, line source, yay”, need to understand better what is meant when people tout the advantages of a (true) line source in the home: they are not referring to the far field. So, when we get a short, truncated-line source in the home, it delivers a mish-mash of near and far field behaviour, and does so in a way that is quite undesirable. That is why Keele went to a lot of trouble to develop his CBT with a curved and shaded driver array: because when he left it straight and unshaded (like the LRS), it’s
bad.
cheers
