Impressive!My last all-Maggie system was 7.1.
Ditto.My last all-Maggie system was 7.1.
To "damp" them would make them sound wetter, surely!due to the small'ish very live listening rooms I have had over the years so I prefer to damp (not dampen) them.
I have mine set up in a super reflective Listening room now. My wife and I are only using them to listen to live albums. All the reflections make you feel like you are at a concert.Amir wrote, “…the designers solved 30% of the physics of building a speaker, and threw you in there to solve the rest! You take on the job of spending what must be a lifetime messing with location, tilt, EQ, etc. to get sound that is good for more than a few select tracks.”
This precisely describes my 30+ years of ownership and daily use of various Magnepans, from SMGs up to the 1.6Q/R and its timbre-matched center and surround companion Magnepans of that era (c. 2000) in a 7.2 system. I did an exhaustive amount of experimentation over the years, settling on the combination of very careful room treatment and the construction and positioning of some free-standing, acoustically reflective and absorptive passive flat baffles directly behind the speakers, to dial-in decent coherence and imaging at the listening position. Once there, I could enjoy the ultra-low distortion afforded by them as compared to most speakers of the day, which was my whole point in getting interested in using them in the first place, having been spoiled by Quad ESL57 ownership.
It was quite a chore getting the Quads and the Maggie’s to play nice with the room and attenuate the multitude of little reflections/delays/echoes, etc. to approach an acceptable degree of focus, at least if I were sitting in head-in-a-vice posture.
Thank the Lord for the modern, controlled directivity approach by JBL, et. al. and newer, cleaner conventional drivers.
In comparison to life with a modern, neutral, low-distortion speaker with more favorable radiation geometry, planar dipoles can give you a seductive and entertaining experience, like wearing rose-colored glasses. And there’s nothing wrong with that if it makes your happy.I have mine set up in a super reflective Listening room now. My wife and I are only using them to listen to live albums. All the reflections make you feel like you are at a concert.
They used to by my mains for my stereo/ht mix and were awful for listening to dialogue.
Well, conventional speakers spill even more reverberant energy into the room, 4.8 dB, if I remember correctly, and that tends to go to the first reflection points on the sides, where it creates artificial widening of the image, just as the rear radiation of a dipole creates artificial depth. Also, omnidirectional bass triggers more room modes than dipole bass so has a rougher LF response -- a phenomenon I'm very familiar with because we've tried to design omnidirectional woofers that sound as realistic than dipole woofers, and you need four properly-positioned woofers to achieve that.In comparison to life with a modern, neutral, low-distortion speaker with more favorable radiation geometry, planar dipoles can give you a seductive and entertaining experience, like wearing rose-colored glasses. And there’s nothing wrong with that if it makes your happy.
That would only be in the low frequencies where the DI of a perfect dipole is 4.8 dB and of an omni is 0 dB. Once a conventional speaker starts to beam and its DI rises above 0, the reverberant energy quantum is more similar between the speaker types.conventional speakers spill even more reverberant energy into the room, 4.8 dB, if I remember correctly,
Actually the opposite: the more room modes triggered, the smoother the LF response.Also, omnidirectional bass triggers more room modes than dipole bass so has a rougher LF response
“Very familiar”?? But I just pointed out you are wrong, so how can you be “very familiar” with something not even real?…rougher LF response -- a phenomenon I'm very familiar with because we've tried to design omnidirectional woofers that sound as realistic than dipole woofers, and you need four properly-positioned woofers to achieve that.
?? But you just finished saying “the conventional speakers ‘spill’ more reverberant energy into the room”, therefore it is they, not the dipole, that recreates the “actual venue”… by your own logic.planars do a significantly better job of recreating what I hear in an actual venue, because the (artificial) reverberation isn't coming directly from the source, something that we know the ear can detect.
…and yet as you say, it is the conventional speaker that, er, ‘spills’ more indirect sound into the room…most of what you hear in a concert hall isn't direct sound at all.
…and I know others have made the opposite observation…planars are the only speakers I've ever heard that can reproduce piano, and I know that others have made the same observation.
I say the opposite. As post #1 shows, this speaker has pretty low ‘quality’, and some speakers even at $100 have more of ‘it’. Once you get into the expensive planars, that gap widens.Finally, for a given quality, planars can be significantly cheaper than boxes,
The word propagate works too.TW ‘spill’ is a value-laden word, how about ‘distribute’?
It's 4.8 dB lower because of the nulls at the sides.I am not sure the actual energy injected into the room is any different; I suspect it is higher for dipoles at the same SPL due to the back wave. However, the direction of the energy (wavefront) is quite different.
Yes, that makes sense.That would only be in the low frequencies where the DI of a perfect dipole is 4.8 dB and of an omni is 0 dB. Once a conventional speaker starts to beam and its DI rises above 0, the reverberant energy quantum is more similar between the speaker types.
True. I'd say "contribute" is the word we want.BTW ‘spill’ is a value-laden word, how about ‘distribute’?
Sorry, but we've done actual listening and measurements. We wouldn't bother with dipole bass if the response weren't smoother -- dipole cancellation makes it inefficient.“Very familiar”?? But I just pointed out you are wrong, so how can you be “very familiar” with something not even real?
They ahem contribute it to the sides. The stage widens and since the path length difference is typically low, the sound is colored, which is why absorption is so often used at the first reflection points at the sides. For recordings made in larger venues, depth contributes more to the illusion.?? But you just finished saying “the conventional speakers ‘spill’ more reverberant energy into the room”, therefore it is they, not the dipole, that recreates the “actual venue”… by your own logic.
They're wrong.…and yet as you say, it is the conventional speaker that, er, ‘spills’ more indirect sound into the room…
Amir, as I recall, listened to one speaker (!) and when I asked how it was positioned, he didn't respond. I'd need to know the size of the room, too -- the LRS is a small room speaker and has no bass in a larger one owing to interaction between the baffle and room sizes; the general rule is the larger the room, the larger the baffle has to be and vice-versa.I say the opposite. As post #1 shows, this speaker has pretty low ‘quality’, and some speakers even at $100 have more of ‘it’. Once you get into the expensive planars, that gap widens.
That neglects the energy from the back wave that also goes into the room...It's 4.8 dB lower because of the nulls at the sides.
Well, see what Newman said above. It's true only of the lower frequencies where the speaker is omnidirectional. At higher frequencies where the radiation pattern is cardioid, he says that the difference between the box and the dipole is minimal. It's a good point.That neglects the energy from the back wave that also goes into the room...
Debates aside, bear with me for a moment, because this is kind of interesting. At least I find it interesting. No debates, I promise.At lower frequencies virtually all speakers behave as point sources. As frequencies increase a conventional design radiates more to the front and sides whilst dipoles radiate more to the front and rear. I'll quit, no use engaging in another stoopid internet debate.
Interesting. I'd expect them to be easier to place, no backwave to worry about and if the beam is narrow enough, sidewall reflections wouldn't be a major issue. How low does the constant directivity extend? I'd also expect dipoles to sound the same out of the room because they have nearly ideal power response.At this point I’d like to briefly interject into this interesting discussion that my recent experiences with modern “cardioid speakers” (I love that term for the purposes of this discussion) have been exclusively with a constant directivity design, and those are new in my experience. I’ve been amazed at how forgiving they are compared with my old Magnepan dipoles. They’re so much easier to place and their timbre changes little when heard from anywhere in the house! They really do behave uniquely. I‘ll have to bring a pair of “more conventional” conventional speakers (non-CD) back in here to refamiliarize myself with how “they” interact with the room. I’m retired from broadcast audio engineering and its been a couple of years since I’ve listened critically to any of those. I do have some in mothballs that I can drag out for a listen.
