Not really, it is mid-range limited.
Right, but towers will have more capable midranges to keep up with the bass drivers. The LS50's Uni-Q was no doubt engineered knowing where it would hit excursion limits.
I'm looking at KEF's spec sheets. They show a clear progression of sensitivity and volume as you work your way up:
One range of towers sharing a midrange is going to have a top-end volume/sensitivity limit determined by that midrange, but lower models in a range like the R3 are going to be output limited by the bass drivers, and have that midrange's sensitivity reduced in crossover to match.
- LS50 Meta: 85dB sensitivity, 106dB max
- R3: 87dB sensitivity, 110dB max
- R11: 90dB sensitivity, 113dB max
- Blade: 91dB sensitivity, 117dB max
PS I note the LS50 Wireless II does push up to 108dB full-range with its intelligent bass extension. That does suggest at least 108dB should be possible above an HPF in the LS50 Meta. If you too use a 200W amplifier like the Wireless II...
KEF states the R2c also with 87 dB (2,83 V / m), same as the R3, according to above plot its around 85-87 depending on the range and averaging.I honestly wouldn't KEF's sensitivity ratings at face value, specially after Erin reviewed the R2c (allegedly 87.5 @ 2.83V).
Why, KEF states the R2c also with 87 dB (2,83 V / m), same as the R3.
The KEF measurements show clearly that the sensitivity increases:it's 84.8 dB in reality, and like i said, the addition of an extra woofer on top of the R3 did not increase sensitivity, I doubt the towers show any significant difference in sensitivity.
KEF didn't claim the R2C had greater sensitivity than the R3.
The R2c and R3 aren't directly comparable - it's sealed versus ported.
No, but you claimed that the addition of more bass drivers will raise the sensitivity, but from the data we have that is not necessarily the case. the R2C should theoritically have 3dB higher sensitivity than the R3.
R3
R5
R7
R11
Source: https://us.kef.com/pub/media/documents/rseries/rseries2018-white-paper.pdf
The higher models are truly tuned warmer but even there for example the R11 is around 87-88 dB while the R3 is around 85dB. Obviously the first number is the limit of sensitivity of the used Uni-Q.If you would pay a little extra attention, you would see the sensitivity dropping off in the mids and highs as you progressively add more bass drivers, with the R3 being the flattest accross the board. Also i just realized how solid the reference line-up is! really state of the art.
I find it hard to discern the trend - the waves seem different in each measurement. Bass is clearly going up monotonically, but the mid and upper vary.
If anything it looks like the tweeter is failing to keep up.
R11 and R3 have massively different midrange, but R5 and R7 look very similar. Looks like R7 could do with a midrange boost.
The KEF 3-way coaxial driver is quite different though to the LS50 and other 2-way models one though, having only a tiny surround so it has to be crossed quite high(er).
12 db slope. Harrison labs makes various Hz passes both high and lowAnyway, another random thought - is a passive high-level HPF for the speakers an option? Seems like it could be the answer, but I can't see anything readily available off-the-shelf. I guess filter results depend on speaker impedance too much, so it's not a viable generic product?
My advice would be SVS PB-1000 Pro. I can vouch for SVS's current line-up (ported or not) easily. Only this model got high-level input. So with Hegel, it's your only choice in the current SVS line-up.
https://www.amazon.com/FMOD-Crossover-Pair-High-Pass/dp/B0006N41KG
You're welcome. I thought they made 24db too but I can't find any. Most of the reviews that rate them low seem to misjudge the pass db per octave or mistakenly think it's a brick wall.this is amazing! thanks for sharing! 12dB slope is a bit slow though, wish there were more slopes option.
Yes, I meant above the surround of the mid/woofer not the tweeter.The design does appear different between the Rx's and LS50/M, but isn't that primarily in the flange/suspension and overall woofer diameter? I think the tweeter waveguide is identical in size and shape.
