Digital EQ is great for "room correction" and will "work" as a substitute for tone controls but compared to one knob that controls 5 bands at once in real time it is not really the same thing.As long i have a 10 band peq, i dont miss tone controlls.
Dont get you what you talk about?
As are many recordings. Sometimes simple tone controls can make them easier on the ears, so poor tonal balance doesn't distract from the music.I no longer have tone controls, either, but my software provides balance control, volume control and DSP.
Because most domestic rooms are bad.
Tone control parameters can be adjusted on some equipment. Even without adjustment the Baxandall circuit is one of the most popular and widely used circuits all time in audio equipment. A better question is why would you want to do something different than something that is proven to be more or less perfect for the application. The answer in the audio business is to "save money for the manufacturer" but that is hardly a benefit for the consumer.With a modern digital PEQ you make two shelfs if you like to simulate tone controls. But who would like to simulate unflexibel tone controlls?
Probably me! Because I will call his bullsh*t, bullsh*t, in a different reply but I aim to make it PC.To whom or what is this addressed?
We're talking about one-time tweaks that will be undone, usually for a recording that doesn't sound right. Do you really want to take the time to dial things in precisely when doing that?Typical tone controls are not realy usefull. They influence to wide band. Gently used sometimes they can be ok. But we live in digital age and have much more controle-
Bad recordsI had a buddy ask me one day "why don't you have bass and treble controls". My response was quick "I don't need them". Move forward to today and I realized I no longer even have a balance control.
There is lot's of talk on this forum about EQ and room conditioning etc. Maybe I'm daft but I really don't get why all that stuff is needed unless you have a really bad room or gear. I really like the "less is more" approach.
I recently upgraded my system by downsizing and in my impression getting rid of a pre-amp and turntable and replacing them with a DAC has been the biggest upgrade I've ever made.
This is a common point of confusion. Specifying the purpose clarifies the confusion.We're talking about one-time tweaks that will be undone, usually for a recording that doesn't sound right. Do you really want to take the time to dial things in precisely when doing that?
We can use live acoustic music as a reference, but even that is a moving target. It sounds different depending on the room size & shape and where the musicians and you are in the room. That suggesting having a wide tolerance for recordings that sound different yet are reasonable....
My issue with modifying the sound coming out of a "quality pair of speakers' (while using 'equal-quality audio hardware') is that I have ABSOLUTELY no friggin' idea, how that 'sound' was originally born and how it was 'worked' to maturity (i.e. release) based on other humanoids and audio gear.
So, who exactly do I think I am to even touch a tone control? ...
I've contemplated getting a Schitt Loki tone control unit, partially because I think naming tone controls after "Loki" the Norse trickster god is witty. And additionally, they appear to be simple, functional, and reasonably priced.The main use I find for tone controls is very soft or very loud listening. When listening at low levels quickly and easily being able to add bass and a little treble really helps. I also find if I listen very loud turning down the bass and treble a little bit helps. The Fletcher-Munson curve explains this https://en.wikipedia.org/wiki/Equal-loudness_contour
It's worth comparing with the JDS Labs Subjective 3, which gives you the option to buy ready-to-use, or build yourself as a kit. I built and measured a Subjective 3, posted results here.I've contemplated getting a Schitt Loki tone control unit, partially because I think naming tone controls after "Loki" the Norse trickster god is witty. And additionally, they appear to be simple, functional, and reasonably priced.
