Careful. You can pick out some tube amps.
Yes, because they are more likely to add distortion. That is why some people claim to like them. They call the distortion "warmth". I don't get the attraction.
He may not have even done that.If there's any magic that eludes measurement then Bob Carver wouldn't have beaten Stereophile by plain old nulling and distortion knobs.
I handled a large Yamaha amp with the class A switch and like you experienced with your amp the difference was not there. Sounded exactly the same. I handled many class A JVC and Technics amps and they ran class A for the first little bit of power and they sounded the same as any other amp when on a switchbox and comparing them. Class A is a very broad brush stroke that encompasses many amps from many manufacturers and so the comment made by @A.wayne is too broad a stroke and makes little to no sense.My DAP (Hiby R6 gen 3) has an option for class A or AB. The only difference I can detect between the two is that class A gets the DAP too hot to carry in a pocket and runs the battery down very fast. No audible benefit at all.
The class A option is useless.
True. I need to remember to state qualifiers, otherwise we'll be testing surfboards against battleships.![]()
I see a point in using class AB for headphone amps, primarily due to a lack of class D headphone amp products.
Class D headphone amp? That might be a first.I believe the headphone amp in the Wiim Ultra is class D and it works very well.
I'm going with 'yes' then. But no matter- you and I are on the same page.Maybe, i just tell again. I dont care about the efficience of 5w tube amps.
Err, academic response not to the question.
Class A operation has superior sonics to the others, for headphones they make the best choice , class D is not for sonics but for high power @ reduced cost, size , etc ..
Same for class H , AB , B , these are all compromises to sonics based-on application where high biased class A is prohibitive ..
Class A is not best for high powered application , well not all ..
Regards
Sy, you can take this post as a CitationCite needed.
Nope, not all. There are some specially designed modulation schemes that make it possibly to (almost) omit the output filters. They are not particularly high-powered devices, but they do exist:which is all class D amps used in audio
I was thinking of the kind that use computer controlled output to negate the filter. There are also uses such as in subwoofers such as in this paper from the AES. But I was being too general...Nope, not all. There are some specially designed modulation schemes that make it possibly to (almost) omit the output filters. They are not particularly high-powered devices, but they do exist:
Hard to beat (Beats? ha ha) Apple's AirPods Pro 2, they're quite effective. A friend who has tested them all-he loves toys-said some others might sound a bit better but the ANC not quite as good. Over the ear, that Sony whatever model is damn amazing, I literally could not hear the salesperson talking next to me!Well it is about time for me to adopt ANC. Got a plane flight coming up soon too.
I have over 70 years listening experience, have designed and built quite a lot of equipment in the professional arena, and in my experience to date quality of design and implementation is the primary differentiator of audio amplifiers. To the extent that, given adequate design and implementation, it is impossible to differentiate between high quality amplifiers in a true blind test within their power ratings. It is a lasting source of regret that the letter "A" was chosen for the first of the series of descriptions of output device conduction angle. If they had started with "Z" things might now be different. I sit here surrounded by 2000W of Class D (and some 500W AB) audio power devices in my little studio, while most of the heat comes from Class A microphone and line amplifiers and valve/tube-based equalisers. I doubly emphasise the requirement for competent design and implementation, having suffered Clive SInclair's early attempts at Class D back in the '60s (and his class AB, come to that). And I say this having owned examples of many of the best valve/tube amps in my various studios, all of which I refurbished and sold at a good profit to otherSo in your 8 years as a member here, you haven't read or learned anything? Maybe start with this thread.
So, are Class A power amplifiers actually any good?
As per the title, despite their inefficient design, heat output, cost and weight, class A power amplifiers are often upheld as a kind of 'gold standard' on many forums with out objective justification. I note that very few, (I can't recall one), have been tested on this very illustrious site...www.audiosciencereview.com
I'm trying to think: why would my amps (tri-amped system) be idling? If they are, it would only be for the length of time that it takes to get music going.Having another bad day again, huh?
Here are some Japanese amps and their idle power drawn (source: Stereoplay magazine - Germany).
Yamaha M-5000 - 56W
Yamaha A-S3200 - 50W
Yamaha A-S1200 - 50W
Accuphase E 460 - 82W
Luxman L 509u - 77W
Luxman L-505uXII - 93W
Luxman SQ-N150 - 82W
Luxman L-550AX - 168W
Luxman MQ-300 - 154W
Luxman L-595ASE - 160W
Not to mention other brands from other countries.
Octave Audio Jubilee 300B - 331W
T+A M 40 HV Anniversary Edition - 220W
T+A PA 3100 HV + PS 3000 HV - 198W
Dan D'Agostino Momentum Integrated - 210W
Dan D'Agostino Progression Integrated Stream - 120W
Pass INT-250 - 240W
Rotel Michi M8 Mono - 93W
Krell Evolution 402e - 342W
Let's not even compare efficiencies when musical power is drawn!
+1
Quadri amped here, three Behringer A800, Crown xls 1002. How much watts consumption in idle?I'm trying to think: why would my amps (tri-amped system) be idling? If they are, it would only be for the length of time that it takes to get music going.
I'm pretty sure that is not an issue in substantially raising the average.
Ah, Motor Trend's car of the year in 1980
