Petrushka
- Joined
- Jun 29, 2024
- Messages
- 1,757
- Likes
- 2,048
So why not high bias class A for everything?
This is a high fidelity amplifier class. Class A amplifier's output transistors run at full power whether there's an input signal or not. When there's no signal, the transistors' power transforms into heat. When there is a signal, the power goes out the speaker terminals.
Also, each Class A output transistor amplifies both the negative voltage and the positive voltage parts of the signal's AC waveform, increasing the workload and raising more heat. Class A amps function at a 25% efficiency level and the remaining 75% of their power is turned into heat.
There are no turn-on, turn-off, warming, or cooling cycles that would affect the signal flow. In this class, you get distortion-free performance. Besides there is no switching going on, meaning there is no induced high-frequency interference. Pure Class A amplifiers are rare and expensive.
Difference Between Class A, AB & Class D Amplifiers Explained | Ooberpad
Know the difference between Class A, AB & Class D Amplifiers. Read more to understand how do these differences affect the efficiency & sound quality!
