@restorer-john great stuff
OP has stated he simply wants to use the unit as a preamplifier, my directions are to do just that in a non-invasive, reversible way.
Troubleshooting and repairing the power amplifier (if it actually has a fault) is a whole other story.
No need to ground the lifted R71/72 leads. They are there for him to inject a signal later should he wish to.
The fact that one channel is fine, suggests the power amp final stages are not actually damaged. The Class A front end (uPC1298), may be damaged, or the fault could be upstream. The uPC1237HA protector IC drives a single speaker relay. If there is a DC offset (from a fried output IC) the relay won't connect any speakers at all. So there is no harm leaving the power amp stage powered up, unused and input floating (it's tied by 100K to 0V anyway).
Don't cut any wire, just make some pins with solid hard wire to connect.I don't want to cut the wrong wires
To me it seems like it would be much easier to connect like John described. Are you in the USA or Canada? I can send you some shielded wire with solid 26AWG conductors (~0.016" dia). You should be able to slip the conductors underneath the jumpers and resistor leads and kind of wrap it around to make the soldering pretty easy. There are 2 conductors plus shield wire though, so you won't use one of the insulated wires.Hi John, I really appreciate your support on this. Thanks for the suggestions but concerning the other suggestion I don't have the tools nor the dexterity to accomplish that task, dang those parts are way to small for me! I'll take my chances with the ribbon wire, I don't want to cut the wrong wires so could you help me out one last time by telling me on what side are the desired wires, so A or B? Thanks again.
I pull but cannot get it to budge, I'll figure out a way but need to know on what side the wires are situated, is it A or B ?What does the end of the ribbon cable look like when you disconnect it?
Hi John, I've completed the task and tested it on the AMP. 2 things: number one In order to get volume I must turn the know to at least 3/4 of it's travel and number 2 there's quite a lot of humming and buzzing, is it possible that my cable is picking this up from the transformer? If so how would I go about shielding it?OP has stated he simply wants to use the unit as a preamplifier, my directions are to do just that in a non-invasive, reversible way.
Zip tieing the shielded output cable to the power transformer secondaries is a no-no. You also must keep the three wires you've pulled apart as close together as possible, not leave them floating up in the air and route the cable carefully. Have you put RCAs on the rear panel or just run the cable out? If you have put chassis mount RCAs, use isolating washers and the PCB earth, not a chassis earth, or you may get hum from eddy currents in the chassis.
The front end is passive in direct mode, so the level will be relatively low. All you have between the line source and the output in direct mode is a 330 ohm resistor and the 100K pot. There is nothing wrong with using the volume pot up that far, as it is really just an attentuator in this case. Obviously, if you are using the RIAA stage or the tone controls, you switch in some active circuitry.
Maybe you did not ground the shield? I don't know if you want to use shielded cable anyway since the ribbon is not shielded. You might just want small wires well routed to the RCAs on the panel. Anyway I'm afraid I'm not going to be able to help much, although I'd still be happy to send the shielded wire (I am in NH so it should get to you quickly).
Be patient with John - he'll probably get back to you.
Hi, I'm not getting answers from John, do you have any suggestions?
Use J153 (jumper) as your ground point (easy to solder to a top board link) for any shielded cable you are running for a 'pre-amp out'.
