Hi my KA-4020 is not working properly 1 of the channels is not performing well. I'm not a tech but I would like to be able to bypass the amplification stage and use it as a preamplifier instead. What would be the easiest way to go about it? Thanks.
Thanks Don, I knew that and the reason I want to use it as a preamp is to be able to use the volume control and the rest. I'm thinking that if I could redirect the output volume to a pair of outboard RCA jacks that would be great. I have the service manuel but have absolutly no idea how to read itUse one of the tape outputs but you'll probably have to add a volume control.
That's exactly what I want to do! Thanks I'll try to connect John, have a good day and thanks again!The black stripe is a ribbon cable containing multiple wires. If that is the amp board to the left, you may be able to pull the ribbon connector, remove power from the amp (to prevent it from oscillating or whatever), and tap into the amplifier's input from the cable to a couple of RCA jacks.
@restorer-john may be able to offer more help; he is a font of knowledge for things like this.
Do you know the problem is in the output amplifier and not before?
My next advice would be to use the headphone output with an adapter cable to your power amp. Check to see that the problem does not exist in the headphone outputs, though, as some (at one time many) receivers just route the main outputs to the headphone jack.
If that does not work and/or you want an "internal" solution but can't read a schematic, my advice would be to find a techie friend who can, and have him/her solder a couple of cables from before the power amp (after volume control and processing) to one of the tape outs.
I'll do my best to find the in the amp, thanks!Sorry, late to the party.
Here's the relevant part of the schematic and where you can tap off the preamplifier front end from the power amp. Pins 1 and 3 of connector 2 (the ribbon cable) are R and L respectively. (obviously referenced to ground Pin2)).
Reference ground pin 2, is that the 2 in the circle indicated LINE-E ? If you look at the image is 1 to the left or to the right of the picture, the picture that I took earlier?Sorry, late to the party.
Here's the parts highlighted on your picture, you can do it all from above (snip one leg of R71/72) and that will save a whole lot of grief getting the power amp board off the base plate.
...I would like to be able to bypass the amplification stage and use it as a preamplifier instead...
