Do you have driver measurements available for them?
I do not.
Elaborate
Zaph measured an ATC dome back in 2011. Ctrl-F.I do not.
And I'm assuming a hard concrete floor in a garage.Pure conjecture based in my own ignorance, but perhaps vertical reflections? The M16's 2kHz-4kHz dip in his room measurement mirrors it's vertical dispersion graph, perhaps suggesting he's picking up a lot of floor and ceiling reflections (mostly floor). As the R3 has a lot more vertical energy he's similarly picking up a lot of positive reinforcement from both planes in its measurement.
Unless I am misunderstanding you @QMuse, you do not want to gate the impulse response in this case. Gating it turns just turns it into a quasi-anechoic measurement. Amir was looking to see how the PIR matches the actual in-room curve.
Been wanting to say this about bass tuning but I kept forgetting. Thank you!! Yes, much smaller room sizes for many folks over there. Yes many here have that as well, but a number of our systems are tuned for very large living spaces.I'd suggest, KEF being British and all, that they're tuned for typical British rooms where they will likely be close to the front wall. Indeed KEF bookshelf speakers I have tried seem rather lean unless they are reasonably close to the wall. The other observation I'd make, is that once the bass is brought into balance in this way, they tend to sound rather polite at the high end.
I have made a breakthrough in finding the conflicting subjective listening tests to objective data. It opens a huge can of worms though so I need to do more testing to confirm hypothesis. For now, I can make the R3 sound almost as gorgeous sounding as M16 with a simple hack.
For now, the science is mostly correct. As was my subjective listening tests.
All the guesses here including mine were wrong. At least not the high order effect. In hindsight though, it is an obvious thing.
Well, the alternative was to let you all keep speculating/accusing me of being deaf.Don't tease us like this!
Probably although more so the far field tests.
Would this affect all previous speaker reviews potentially? (in terms of the subjective listening impressions)
$5 on a bottle of wine
Hahahaha classic.It must have something to do with a wife and a kitchen. If not, it can't be trusted
Sorry guys, I loaded wrong PIR for M16.
Here's how they look when range 1khz-10kHz is matched:
