I've been trying to work out the implications (for me!) of the sensitivity measurements that Amir made in this review. He wrote:
I'm assuming that the test involved sending a consistent 2.83V rms signal to the speakers across a range of frequencies. The impedance of the R3 at 40Hz is 3.2Ohm so if my assumption is correct, this means that it takes 2.5W of power to generate 80dB at that frequency.
I tend to listen pretty quietly by the standards of this forum as far as I can tell. According to an iphone app, typical volume would be around 65dB at 1m from the speakers. Nevertheless I am sure it makes sense to build in headroom for dynamic range. But how much headroom would you build in? How much power into 4Ohm (despite the nominal 8 Ohm impedance of these speakers) would you want, for this kind of situation? It seems to me that 25W ought to be enough for my purposes, and any half-decent amp can do that or more, so I have little to worry about... But "anplification requirements will be significant" seems to push in the other direction.
I realize this question is a few weeks old. In your situation you do not need a high powered amplifier at all. Even a 10watt amp will be perfectly fine.
Low SPL listening is simply not using much power. 65db averages with 70-80db peaks is low SPL by the standards and norms of HiFi. (when I sit down for a session it is common for averages to be at least 80-85db/90-95db peaks or higher, even 90db averages/100+db peaks which is very loud by the meter level but in reality with low distortion speakers and high powered amps sounds about right for that realistic experience.)
Many people are in your camp which is why so many low powered amps satisfy so many.
If you ever plan to crank it up and sit 4 or 5 meters away you will want that 100+watt amp.
Subjectively in my experience the R3 did not require more power than any typical monitor I have tried. It is a generally 'normal' contemporary era speaker.(The Phase angle and impedance around 40hrz is a bit rough though so bass heavy stuff will suffer there at SPL with weak amps)
Can we assume from this chart, that midrange-high section has higher impedance? Does speaker impedance affect clipping?
No need to assume, that is what that chart is.
Yes, speaker impedance affects clipping. When the speaker is playing high energy notes/sections in the ranges below 4ohms some amps will clip far before others. (some amps even have trouble with 4ohms but that is uncommon on new/contemporary amps) There may also be a limiter built into the amp.
You also have to look at the phase angles in conjunction with the impedances. The R3 is a generally a normal speaker except around 35-45hrz where the impedance is low and the phase angle high. If you listen at SPL to tunes with high powered energy releases there then use a beefy/well designed amp. (note how easy it is drive a ported speaker at the tuning frequency where impedance rises and phase is zero, of course a very high rise in impedance can also be an issue.)
Otherwise your amp power level capability and listening distances and musical tastes will affect clipping. All clipping is not equal either. Some clipping is perceived as euphonic, some horrid and some not perceived at all, as I have read even 6-10db of clipping can be said as inaudible in common situations for many listeners.
