The difference is, the hump on the R3 is at frequencies which we are more sensitive to notice with deviations from flatRelatively.
But agree.
Also even Neumann is not perfect.
And Genelec is not perfect from 100 to 500Hz. It's comparable to R3.
But agree.
Where is scientific proof to 'more sensitive'?The difference is, the hump on the R3 is at frequencies which we are more sensitive to notice with deviations from flat
Right here: https://en.wikipedia.org/wiki/Equal-loudness_contourWhere is scientific proof to ' more sensitive'?
Have no idea why you want to compare the R3 to these other 2 speakers but the treble hump is fairly obvious.
Bump?! Firstly it was a hump.Right here: https://en.wikipedia.org/wiki/Equal-loudness_contour
This talks about the compensation for it, because it also varies by SPL level. But its well known that how loud we perceive something is heavily influenced by the frequency, which is also discussed on this wiki page. Its also the reason dBA as a measurement unit exists.
Just want to note I didn't look at the R3 measurements and in what area the bump is, only wanted to show how our hearing is not equally sensitive across the frequency range we can hear.
the member who posted the pic here is not a new member. So must be legitimateHI Everyone
I'm new to this forum and looking eagerly for Kef R3 meta release.
I saw some post here , reg KEF R series meta update ,where in ISE 2023 exhibition and how legitimate it is?
I checked the ISE 2023 website and there is not stall available for KEF.
One of my colleague is currently in ISE exhibition in Barcelona , and he said he cannot see KEF stall over there as well. I asked him to check again...lets see..
It seems to be lots of rumours around and no official announcement from KEF either.
I hope in 2023 , they will release R3 meta version..Lets wait and see..
I don't know why you are responding like that to me. I'm just explaining that human hearing is no linear over the entire frequency range. You know...the thing you asked for proof for.Bump?! Firstly it was a hump.
Luckily we have room correction. Speakers with an irregular directivity are hard to adjust, but frequency, if it does not need a massive increase or reduction, can be adjusted pretty well.No not catastrophic at all. R3 are excellent speakers. Many others don’t come even close. But in some rooms they might be perceived as a bit bright (as the data from @VintageFlanker showed). Only one way to find out - listen at home.
And that is exactly the reason why I think it is futile to describe individual listening impressions. Everyone has a different room plus on top certainly different preferences and biases and different associations with the adjectives describing perceptions.
I listened at home and partly owned R700, Reference 1, Reference 3 and 5 and also changed houses in between. The change in houses (rooms) had a much bigger influence then the difference of the speakers btw.
I stayed with the Reference 3 and two KF92 and me writing here about my subjective impressions (non level matched and sighted) would be a waste of my time and everyone else’s having to read it. ;-)
Only thing is theoretically the resolution of audio would be limited by the sampling rate capability of the DSP. But since hi res isn’t audible it’s not a problem, but for folks who has invested in hi res, it’s a bummer!Luckily we have room correction. Speakers with an irregular directivity are hard to adjust, but frequency, if it does not need a massive increase or reduction, can be adjusted pretty well.
It’s mentioned, that it’s demonstrated by an installer not by Kef. So possibly Kef won’t be there in stall list.HI Everyone
Absolutely.Luckily we have room correction. Speakers with an irregular directivity are hard to adjust, but frequency, if it does not need a massive increase or reduction, can be adjusted pretty well.
Why are they hard to adjust? Can anyone say why is it hard? I never got the concept why it’s hard to adjust a speaker with irregular directivity.Luckily we have room correction. Speakers with an irregular directivity are hard to adjust, but frequency, if it does not need a massive increase or reduction, can be adjusted pretty well.
I might’ve misunderstood but he said firs r pic is from his dealer rest from his installer buddy. This must be KEF stand, no one else would be able to present new speakers but them.It’s mentioned, that it’s demonstrated by an installer not by Kef. So possibly Kef won’t be there in stall list.
See F Toole “Sound Reproduction” it gives the details of the argument behind it.Why are they hard to adjust? Can anyone say why is it hard? I never got the concept why it’s hard to adjust a speaker with irregular directivity.
At a given listening spot, what you get is the combination of the Orginal signal played from the driver and the reflections.
Even with a flat speaker, the room reflections added would make the response non flat at the listening spot.
If we eq this speaker, essentially the direct wave, or the Orginal signal needs to be altered.
Isn’t this the same case with a speaker without irregular directivity?
Can you point out the page number?See F Toole “Sound Reproduction” it gives the details of the argument behind it.
you can tell him to have a look besides the db audiotechnik booth,HI Everyone
I'd say it is not audible for most people. Amir (and probably others too) has demonstrated that he can distinguish, but that's because he's a trained listener and for years, his job involved actually listening for sound artifacts.Only thing is theoretically the resolution of audio would be limited by the sampling rate capability of the DSP. But since hi res isn’t audible it’s not a problem, but for folks who has invested in hi res, it’s a bummer!
And perhaps why the R3 stands are 24"Also, that’s at a fatigue prone area. Now I think may be there is a reason why the floorstanders have rhe midrange bit below the ear level. When you measure it the measurement is done on the midrange axis. But in reality when you hear it, your ear is somewhere in between the top woofer and rhe midrage or directly facing the woofer. So, that bass slightly drowns the treble hotness.
The room is 21x19 and we listen as far back as probably 15 ft or so. Movies can be anywhere from 60-72dbYou need to define large and your avg listening SPL.
My large would require the R7 plus 2 subs and the center.
