Yep, you should be - it would be interesting to hear with what theory would
@napilopez come with in case he wouldn't notice it so quickly as you did.
You can't fool me! Jk good thing I didn't read your post earlier
Completely agree with all you say
My point is, though, that we just don't seem to have the crucial piece of evidence tying wide horizontal directivity to listener preference.
Now I do think that, looking at a variety of different data as a whole, it is reasonable to speculate that wide horizontal directivity is a factor (independent of dispersion generally) in listener preference. In particular, I believe that we have evidence tying wide horizontal directivity to perceived spaciousness, and some additional evidence correlating spaciousness with listener preference.
However, I don't think we've got those key pieces of evidence that would connect these dots and turn speculation into observation.
Until them, I guess I'm just more reluctant than others here to declare unequivocally that wide-horizontal-directivity designs tend to be more preferred than medium- or narrow-directivity ones.
Totally fair. Part of me feeling more strongly about that then you has to do as well with the research on preference for more sidewall reflections. But at the same time, I'm a very strong believer that directivity is a matter of preference, so just because a majority might prefer it, including myself doesn't mean it should necessarily be a design goal.
Anway, I know we're pretty much on the same page, but for anyone else following along, just wanted to drive home the point of how misleading the ER and ERDI curves can be with regards to horizontal directivity and, consequently, soundstage performance. Keep in mind I'm using the ER Fix
discussed in this thread.
Here's the Q Acoustics 3030i's Early Reflections and ERDI curve compared to the Total Horizontal Reflections (also defined in the CTA-2034A, basically the ER without the vertical Ceiling and Floor Bounce) and Horizontal DI, which is the difference between the listening window and Horizontal Reflections. To be clear, AFAIK nobody calculates a horizontal DI curve and it's not in any standard, I just decided to take give it a try since it was a simple alternative.
You can see the ERDI and HRDI give quite different impressions of soundstage performance, imo. The ERDI curve would probably have you think the soundstage performance isn't decent, but the 3K peak and 5K dips are caused purely by vertical artifacts. And as I think most of us know, evidence suggests the primary effect of vertical reflections is to affect timbre/tonality rather than soundstage/imaging.
The same can be seen with the Focal Chora 806, another wide directivity design:
By contrast, here is the Dutch and Dutch 8c, a narrower design which claims to be constant directivity down to 100Hz. I cut off my polar measurements at 200Hz due to limited quasi-anechoic resolution, but still, you can clearly see the constant directivity nature far more in the HR and HRDI curves:
The vertical influence on the ERDI means you don't see the effect of the cardioid horizontal directivity quite as much, but the Horizontal DI is practically perfect -- almost a straight line throughout the measured frequency range. Indeed: constant directivity down to at least 200Hz.
Lastly, a comparison among the three speakers:
Again, the ERDI doesn't tell us all that much about what to expect regarding soundstage performance, but the Horizontal DI makes the differences much more clear.
For comparison purposes it might be useful to use a taller aspect ratio:
While I still prefer looking at detailed SPL plots, and others prefer polar maps, if we
had to boil down soundstage performance to a single curve IMO the above approach would be better. ERDI is still more useful for telling us about how EQable a speaker is though.
Anyway, sorry for the tangent. Since directivity always comes up in review threads, I thought I'd talk more about how I go about interpreting it.
