- Thread Starter
- #61
Agreed, would make more sense a stack of subs in a mid range series.
Because they can sell 200€ metal joints to rich audiophiles this wayWhy would you need a stacking kit if these subs are not supposed to be moving anyway? Probably might actually be needed which is not that great if you want to stack them on top of some other sub with similar design that is actually not moving at all?
Same as these things you get with a bookshelf to for the same purpose .Suppose the stacking kit is for safety so you don’t bump into the stack and and get one your foot or chihuahua .
Or small children would topple these and get hurt .
My living room is a bit smaller. The KC62 in there is adequate, but I'll probably repace It with a 92 at some point. The 62 can be moved to a smaller studio room in the house, so nothing is lost.We actually have a house . Living room with the subs and LS60 is aprox 5.5m*3m 17 sqm ( 2.4 meters in heigth ), but with large openings to other areas of the house which is fairly open and some walls and roof construction is a bit lossy I sit 2.7 meters from the speakers who are 2.4 meters apart .
This is medium sized living room in swedenprobably a shoe closet in the US ?
I think KEF probably considers them "outdated", hence why going for the more recent KC92.It's interesting that KEF promotes this stack in a setup with the KEF Blade Meta. I would rather expect seeing their Reference Subs next to the Blades but maybe I'm just interpreting too much into that CGI picture.
That distinction is artificial. Signals ar signals. It does not matter if it´s the tank threads rumbling in Fury or an organ piece from Bach.This is a pretty good test with a few measurements. It shows that from 20 Hertz to 50-60 Hertz, it rises together to 98 decibels, before that, the DSP pulls up the 50-60 range. Unfortunately, the video did not mention the musical performance, which was a pity to omit because the KC92 is more of an audiophile subwoofer, not a slow-dynamic, boomy movie box. Starting from the predecessor KF92, this is likely to be a fast, tight, accurate-sounding thing as well.
Yes. The top surface of the bottom sub is slick and the rubbery feet of the top sub have really small contact points. It would be easy to dislodge the top one without the kit (especially if you stack three).Suppose the stacking kit is for safety so you don’t bump into the stack and and get one your foot or chihuahua .
Great review! I'll be pulling the trigger on this soon. Since I have the KF92 already, I'll try some A/B sweeps in REW.This is a pretty good test with a few measurements. It shows that from 20 Hertz to 50-60 Hertz, it rises together to 98 decibels, before that, the DSP pulls up the 50-60 range. Unfortunately, the video did not mention the musical performance, which was a pity to omit because the KC92 is more of an audiophile subwoofer, not a slow-dynamic, boomy movie box. Starting from the predecessor KF92, this is likely to be a fast, tight, accurate-sounding thing as well.
Many thanks for your insight. If stacking only one on top of a fixed surface, one should not expect the movements despite the small point of contact? (Which would be my use case, albeit fixed surface is Arendal 1723 2V sub - but that one is as good as fixed surface, but with limited boundaries)Yes. The top surface of the bottom sub is slick and the rubbery feet of the top sub have really small contact points. It would be easy to dislodge the top one without the kit (especially if you stack three).
"You might very well think that; I couldn't possibly comment."Many thanks for your insight. If stacking only one on top of a fixed surface, one should not expect the movements despite the small point of contact? (Which would be my use case, albeit fixed surface is Arendal 1723 2V sub - but that one is as good as fixed surface, but with limited boundaries)
You know we want to know.Great review! I'll be pulling the trigger on this soon. Since I have the KF92 already, I'll try some A/B sweeps in REW.
Yep, I should be able to A/B them precisely in-room with REW since they are exactly the same physical dimensions. I'm very curious to see if there's any significant bass extension relative to the KF92 and I will also check distortion graphs (though I have no idea how precise they are in REW).You know we want to know.![]()
I'll run REW with Dirac off to make sure we get a good sense of out-of-the-box performance. My KF92 does not generate significant infrasonic output such that I can feel it, but it's probably 5 meters away from my main listening position.I'm super curious to see the infrasonic performance. My KC62 reaches them, but only very close to it at a level that can be felt. These should push a bit more.
That's a lot of space if u can have 5metersI'll run REW with Dirac off to make sure we get a good sense of out-of-the-box performance. My KF92 does not generate significant infrasonic output such that I can feel it, but it's probably 5 meters away from my main listening position.
Perhaps with placement near corners you may get something vibrating but yes, that is coincident with my experience. Five meters is quite a distance.I'll run REW with Dirac off to make sure we get a good sense of out-of-the-box performance. My KF92 does not generate significant infrasonic output such that I can feel it, but it's probably 5 meters away from my main listening position.
