- Joined
- Jun 24, 2024
- Messages
- 1,191
- Likes
- 1,666
So far I've got everything set for the 5.1 setup for my living room in the new home I will be moving into at the end of the year.
However, I'm considering whether or not to dip my toes into the water of changing that point 1 into a point 2. What I currently possess is an old Hsu STF-2. So my first question would be if it makes any sense at all to simply add a second subwoofer? I would plan on doing integration using a miniDSP 2x4 HD, required regardless since my AVR only has a single sub out. Possibly using MSO? Given that, is it sensible to try to integrate a second subwoofer of different make and/or model or should I start fresh with two identical subwoofers if I'm going to do this at all?
Regardless of what option I choose here, my placement options are going to be limited. More than likely one will be on the front wall next to the entertainment center and the other will have to be hiding near the seating area -- either under an end table or using a slim model to hide under the couch possibly. Given the restrictions, and also keeping in mind that I'm trying not to break the bank, the options I've been looking at are:
KEF Kube 10
KEF T2
Monoprice SSW-12
Not sure what else to look at for small/slim subs. The KEFs are really at the very top end of what I'd want to spend on a single sub (and I'd likely try to find a deal on those).
I've also been considering doing in-walls, perhaps. Obviously that has placement restrictions, but then again since my placement options will already be severely limited it's possible the in-walls might actually be a little more free since the second wouldn't have to be hidden beneath furniture? One could even go in the ceiling, maybe? I've been looking at the KEF Ci200SQb-THX paired with their KASA 500 amp. That's a bit of a pricey option, mostly due to the amp, but I've seen it for considerably cheaper refurbished so I could probably float it. There's zero good info about how these actually perform, though, so I dunno.
Anyone have any thoughts/opinions?
KEF Kube 10
KEF T2
Monoprice SSW-12
