I have a custom made equalizer made of capacitors and inductors haphazardly soldered together inside my speaker, works great.To think of equalizing as "messing" and/or "inferior" is an opinion I wish we left behind in the 90s.
If the loudspeaker has smooth directivity but not linear direct sound, equalising it will make both the direct and reflected sound more neutral. A loudspeaker has its own transfer function so a linear input signal doesn't mean its output will be automatically linear. It's all also written in the link I recommended you above.On a speaker with good directivity, on applying an equalizer, we are essentially messing with the signal which goes to the speaker, meaning the direct sound has already become “inferior”(can’t we just call it altered?)
Here's the Reference 5, similar slope there too:
Wait.... we don't? What lol. I think that's taking it a bit far.This is based on the assumption that completely flat on-axis anechoic response is best in a domestic situation. For some reason everyone assumes this is so. But we don't really have a reliable reference or evidence to that fact.
Toole - Sound Reproduction - Section 11.5 said:Starting with my earliest listening tests in the late 1960s, through a prolific research period in the 1980s (see Figure 5.2), up to the present (see Chapter 12), it has been a monotonous truth that in double-blind listening tests, the highest rated loudspeakers had the flattest, smoothest on-axis and listening-window frequency responses. Listeners liked neutral, uncolored, direct sound. Beyond that, loudspeakers that exhibited similarly good behavior off-axis achieved even higher scores—reflected sounds would then have similar timbral signatures. These findings have remained valid in many different rooms over the years. These were small rooms: stereo listening rooms, home theaters and recording control rooms. As has been discussed earlier, listeners have a significant ability to separate the sound of the source from the sound of the room (Figure 5.16). The two sets of information appear to be perceptually streamed, with the result that loudspeakers retain their relative sound quality ratings in different rooms (Section 7.6.2).
With regards to finding the "right" voicing: To avoid EQ isn't a goal in itself in my opinion. Especially in the bass, each room will be different - and to some extent your musical preferences will affect your tonality preference as well. So to have EQ available will be positive in any case.
Beyond that I think you will find relatively few speakers that are voiced with an upwards tilt towards the treble. And I think you will find even fewer people that find them to sound good. So then you're left with speakers that are either neutral, with a slope emphasizing the bass or (relatively common) you with the smiley-graph (emphasis on both bass and treble). In the long term I would suspect most people will prefer speakers that are neutral, or with slight emphasis towards the bass.
Yes, I think that's fair. For active speakers, honestly, you can make the tilt simple enough to change, and it would probably be a good form of simplified tone control. It would be an interesting way to gather data as well as long as you had enough products out in the wild. I know that Buchardt briefly talked about doing something like this.
I think it would be pretty interesting if someone gathered a few thousand data points this way.
Yep, the plan for our next active is one "reference" setting along the lines of what we've been discussing here, one that is perfectly flat, and one with even more downwards slope for reflective rooms.
I'm afraid it will take a number of years to collect a few thousand data points though.
You gotta deploy a few thousand speakers, let the users select an EQ, and then collect that data somehow.
End of the day, they do tune the final part based on subjective listening , as opposed to the popular theory of looking at the graph and deciding. When other manufacturers say that, people here get attack them back , which isn’t fair in my opinion. No manufacturer produces their speakers without their listening tests, by real people, and tweaking based on what is listened. Simple.@jackocleebrown Thanks for your post regarding tuning of loudspeakers. I have discussed this widely with Mr Sigberg and others.
After studying third party measurements from several of your products, a slight pattern appears, which I wonder if you would like to confirm. The larger models, like R11, Reference 5 and Blade 2 meta, seems to have a bit more tilt than for example the LS50W. Is this simply a result of doing listening test for the larger models generally in larger rooms and on longer listening distances?
It is great to see that KEF has such a scientific approach. Many manufacturers claim to have that, but in your case, it seems to be a bit more than just a claim. I especially love the small tricks with the pole pieces and the bass ports used in the R-series.
If I may interject here, that's not what I wrote. Objective data is not discarded at the listening room door. Nevertheless, feel free to judge our product however you see fit: objective or subjective, we aim to do a good job.End of the day, they do tune the final part based on subjective listening , as opposed to the popular theory of looking at the graph and deciding. When other manufacturers say that, people here get attack them back , which isn’t fair in my opinion. No manufacturer produces their speakers without their listening tests, by real people, and tweaking based on what is listened. Simple.
What I understood is your company uses objective data to develop the speakers but your final product still is tuned by ears on the top of it.If I may interject here, that's not what I wrote. Objective data is not discarded at the listening room door. Nevertheless, feel free to judge our product however you see fit: objective or subjective, we aim to do a good job.
I dont think that’s the case, it’s possible to understand the sound profile of any speakers by the data. But to do that, you need some real world experience of real speakers, some measuring bright, some dull, some with wide radiation, some with point sources and so on.It is interesting how some people seem to believe that objective data and listening somehow tells two entirely different stories. Not to point my finger at anyone, I just find it interesting.
How do you know this is the case? Do you record your own cymbals?Kefs cannot produce the cymbals exactly like how they are in the recording unless you eq it up. Agreed it’s pleasant, but then again it’s not how it is in the recording.
Most folks who end up buying these won’t care about eqing. As per this logic, there are 1000s of “pleasant” sounding speakers in this world each of them thinking this is how I make my speakers fatigue free.
Good thing is Kef can be eqed, but most others cannot be.
The dirty little secret of audiophilia: your speaker's passive crossover includes..(drum roll)...EQ!!!!I have a custom made equalizer made of capacitors and inductors haphazardly soldered together inside my speaker, works great.
Yes, you understood correctly. I took your previous post to mean that the final part is done by listening only, which is not the case at KEF. Listening is also used during development, we typically make quite a few early prototypes too. Personally I think it would be rather remiss of us not to listen whatsoever. Even if you take a view that objective data is enough to fully understand how a speaker sounds, this comes from experience and we have to build and maintain that across the team. Plus, our whole team are audio and music fans - listening products we've worked on is very motivating, and trying to understand the perspective of our customers is very important too.What I understood is your company uses objective data to develop the speakers but your final product still is tuned by ears on the top of it.
