DT, is this a raw measurement of the 2123? I had read about a rising response... If it is corrected in the measurement, would you mind sharing the XO/comp circuit?
If used naked or in an open baffle, what would you say would be the lower freq limit of the 2123? I am aiming and 250 HZ, and using an AMT on top.
EDIT: looking a closer look, around 560 Hz it does climb about 4 dB. Troes Gravesen has done measurements too, his show a more continuous 5 dB tilt from 300 Hz to 1 kHz.
http://www.troelsgravesen.dk/The-Loudspeaker.htm#JBL_2123H
For me it is either the 2123 ot the 8pe21.
S.
