Clmrt
- Joined
- Feb 26, 2023
- Messages
- 100
- Likes
- 118
I ran across a Stewart PA-100B class A/B power amp in a pawn shop. Seems to have a build date of around 2000/2001. In searching for information, I found a PDF describing the amp, which is equipped with a SMPS supplying Darlington circuits (I think).
They say this:
"More than anything else, it's their power supplies that distinguish Stewart amplifiers from components with otherwise similar performance characteristics. A conventional power supply recharges 120 times per second and consists of a large transformer and large storage capacitors. The Stewart power supply recharges 1,000 times faster - 120,000 times per second. As a result, it requires less capacitance for filtering and storage, drastically reducing size and weight."
Does that make sense? Linear supplies are dependent on 60Hz AC "refresh rate", using capacitors to make up the difference, while SMPS run at "processor speeds" to supply steady-state DC up to it's limit?
They say this:
