Internal Power Supply Choices
mike7877
These ugly things
"Just stick it in the corner!"
NO!
I'm all about convenience too, but not the type of convenience where the manufacturer takes the liberty of a small, current convenience at my expense -
my large, future expense
SURPRISE: (what is it?) Inconvenience!
(..did I mention it's inconvenient?)
^That ugly mess of words and nonsense is nothing... NOTHING! compared to fixing what's left after two Mean-Well IRM 20-15s go belly-up!
I really like my Topping A70 Pro. Really, I like it (except for its two IRM 20-15s...)
I would much rather be working on the L70:
Than the A70 Pro:
(scale is similar in both pictures)
It's not all about the inconveninence, though - yes, it's inconvenient to replace a whole car when it just needed its rusty fuel tank replaced. It's also expensive!
Mr. Manufacturer might have saved 20c by not needing to order the individual parts to stick on the board for the standard, integrated SMPS.
But now I have to pay $40!
I don't know what I'm going to do when my IRM 20-15s eventually give out..
The A70 Pro's "standby" power is between 3 and 4 watts the last I checked, which is about half its draw during normal operation. Since it's powered on for most of each day, I estimate my A70 Pro's average power consumption is 80+% of "on and playing 50mW music"
The MTBF of the IRM 20-15 is "2K hrs. minimum", and they might have calculated it to 10656 hours to some lower standard (a temperature and humidity they didn't provide). The 2K hours probably comes from the 70 degree max case temperature causing an 85 deg C internal temperature, which matches the 2000 hour 85deg C rated, cheap-asz caps they used hid inside!
You can see the L70 has nice, 105deg C caps! Therefore, its power supply is rated for at least 4x as long as A70 Pro (2000 hours, 105C derated to 95C is 4000 hours, derated to 85C is 8000 hours. The L70's external temperature (black matte aluminum) is 32.5C, A70 Pro is 41 deg C.
The A70 Pro's temp at the top is 41C - the case temp shouldn't be too much (if at all) over 45C:
Mean-Well: 2000h 85C > 4000h 75C > 8000h 65C > 16000h 55C > 32000h 45C
32K hours...
Is there any way to get these things to last longer? I'm not looking for extreme solutions like a Peltier, but... lol
Oh, they take DC! Should I give them DC? 120-430V!
For a consumer device like this, is a 20-30k hour expected lifespan acceptable?
I don't think it is..
I'm disappointed to learn this about my A70 Pro...
It sounds so good... Goes so loud...
It looks so nice! Its measurements are totally off the chart! (lolll)
If only the power supply wasn't cemented into a plastic box!
I believe that bulk capacitors should be accessible and never glued in or made to be a part of something else due to how important they are, and the way they wear out. Mean-Well could sell a version of these boxes with input caps to be installed externally (except the tiny ceramics)! These SMPS modules are nothing special (in case you thought it was because of the A70s 147dB SNR measurements - regulation is normal few %, noise is normal mV).
These ugly things
NO!
Than the A70 Pro:
32K hours...
Completely agree with the switching power supply being internally cemented in place is a very bad move it`s a no brainer.
Call me a deep thinker or over sighted but it appears to me that most people who are complaining about the power supplies being outside the device are mostly from the competition and there paid dinks who cleverly promote a product only to ask they change there design in some way and smear a perfect design online to discourage people.
Curious how many people they had requesting the power supply be added inside there devices... it`s not an inconvenience at all having an external power supply it`s a long power cord to the power supply transformer like the B100`s I own no issues no hassles the amps are 2 feet above the floor and there is still lots of wire left running to the power supply box.
It would be more intelligent design wise to offer or provide extender wires for those very rare situations people want more length or just make the wires a few feet longer that wire is cheap !
Having an external power supply is an intelligent engineering design keeps the internal heat down and a sales advantage if it fails just buy another one it`s plug and play easy no dismantling the device and soldering involved.
It has set up written all over it hope they see the light and start using only external power supplies many online reviewers are paid off to say certain things and some just repeat what others are saying to add more words to there video to make it longer.
It`s such a stupid thing to complain about making it sound like it`s such a big inconvenience and disappointment...
Can someone explain why the L70 has a smaller power supply compared to the A70 ?
On the spec sheet the performance is so close to identical it`s not even previable to the human ear.
The thing is that when you use something like IRM 20-15, the DC is safe. When you design a PSU circuit yourself, it isn't until you prove it. Speaking of which, anyone see where is the power transformer of L70?
From my very simple google search both are rated for 80 watt maximum draw.
L70 PSU ( power supply unit ) appears the same as the A70 pro in that regard
I just ordered the L70 as the A70 pro I just tried and returning is great I just have no need for an external output port or nicely upgraded screen for near double the price...
In my experience power supply failures are rare, no matter how they are made. I have replaced a computer power supply a couple of times.
I sometimes build electronics and I don't think I've ever had one that I built fail. I used one of those little modules in a car project that needed negative voltage and It's been working for several years. (I've never built a switching power supply or a switching regulator.)
I have an amplifier that blew output transistors a few times, and sometimes that would cause a transistor in the power supply to blow. I eventually replaced the amplifier circuits with a "module" which was essentially a high-power op-amp, and I also made some changes to the power supply regulator. That was probably in the 1980s and it's been reliable ever since.
Are you asking where the L70 PSU is located, it's on the left of the 2nd image of the thread.
You should probably reread the spec sheet. The bellcore MTBF is 10+M hours and the milspec is 970K hours
Oh geez, I didn't see the K after the 10,656.2K hours...
Well I feel much better about my A70 Pro's power supply now!!
And apparently I missed your post...
