- Joined
- Aug 3, 2019
- Messages
- 1,734
- Likes
- 2,744
A couple of questions regarding the topic:
1. There seems to be a very wide range in the values of shunt filter/reservoir capacitors found in TPA3255 chip amps -- e.g. 1000 mF in the Aiyima A07, 1500 mF on the TI eval. board, and 2200 mF in the Aiyima A07 Max. Does more capacitance have any particular advantage in that application considering the higher ripple frequency of an SMPS vs. a traditional linear power supply?
2. Is there any advantage to having this capacitance on the amp PCB vs. at the other end of the cable -- IOW, across the DC output of the connected SMPS at the barrier strip to avoid opening up the amp and either replacing the factory part or adding a second capacitor in parallel?
