ehabheikal
- Joined
- May 22, 2020
- Messages
- 442
- Likes
- 161
Just post the file.Silly me cant get the hang of rew. It is so counter inituative for me.
umik 1 with calibration fileWhat microphone are you using here?
rew detects umik 1 and asks about the calibration file.The curve looks very sloped and dull, in my room that curve would sound like having my head in a sack of wet wool and thumbs in ear… Like Sigberg hint at your microphone may be far from correct . go for a curve and slope that sounds good to you, not just any textbook curve.
To be honest if your your curve actually is like you posted you would notice something is very wrong with the sound.
You may be using your PCs microphone without knowing… Check sound settings in PC and disable PCs own microphone for recording.
I learned here that the inroom response usually slants down, but i feel that this slant down is too much. Any help appreciated. The room has some foam panels that i put, and being a bedroom has a lot of soft furniture.
Now it is clearer to understand. Just take down the 3 peaks below 200Hz to begin with. 2 of them are with the sub, so if it has DSP, just set it for these frequencies and some trial and error until it irons out.I readjusted my sub and got this measurement
No dsp in sub, but i have roon.Now it is clearer to understand. Just take down the 3 peaks below 200Hz to begin with. 2 of them are with the sub, so if it has DSP, just set it for these frequencies and some trial and error until it irons out.
