Hello all:
So I'm getting pretty close to purchasing the Polk L800s for my front L/Rs, but there's a little bit of information I need regarding my amplification first:
Appreciate all the help in advance!
- The L800s require a single-ended amplifier (NOT balanced / differential) to maximize the effect of the SDA-pro technology (you lose 6dB of the SDA-effect if using a differential amp); however, I am not sure if my amplifier has that design or if it's differential / fully balanced
- The amplifier I'm running is the Denon POA-A1HDCI
- If it IS single-ended operating normally if I run it in bridged mode, does that change it into balanced / differential? I'd like to run the front two channels bridged if this is not a concern.
