quench
I bet that does sound great. My MA6900 sounds sweetest at 20 to 50 watts sustained as well. I do run it at 100 watts sustained when I'm in a good mood.
Do I see a Mac integrated there as well? And how did you decide on your sub position?
That's a McIntosh preamp, the C52. It is solid state like all my gear and has a built in DAC based on multiple ESS 9028PRO (IIRC). It is fully balanced (according to MC). I use it in preference to the DAC in my Oppo because I think it sounds better. It is very capable and has tons of digital and analog inputs (no AES tho). I run fully balanced everywhere except the ancient Sony cassette deck I keep for playing our old mix tapes.
I did a crawl for the sub placement. I didn't pick the location for maximum output but selected it for what I thought was tightest/"fastest" perceived response combined with a reasonably pleasing aesthetic. I dislike LF "bloat"as much as the next guy so keeping that at bay is a high priority for me. The JLAs are good so that makes it easier. I will sacrifice absolute extension and level for timbre and clarity but the system doesn't lack LF. There is a notch at about 55Hz. I don't think I can hear it but I can see it. The rig is otherwise relatively flat to 30Hz, and rolls off from just below there which suggests to me there may be more to be had but that makes it fun and challenging, right? It sounds great to me, tuned for music, not video but works well enough there too. It's amazing how two speakers can make sounds seem to come from alongside and even behind you.
The subs are forward of the mains and can fully pressurize the room when called for. If I push either or both subs back into the corner quantity rises but quality seems to suffer. The room isn't as tight/ well constructed as the one we had in Seattle but is better controlled overall because it's dedicated and thus treated. The old room was our living room. Lots of domestic compromise there, much less here.
I tune the subs one at a time by reversing polarity to the nearest speaker (the far one is muted), running the matching tone for the desired crossover point, seeking to deepen that notch (using an SPL meter....my phone...hehe!) and then tuning via precise, small incremental adjustments of level and phase, both being available on the JLAs. I use an analog JLA CR-1 crossover which includes both high and low pass filters (and other stuff). I have always believed in using a dedicated crossover rather than just the sub's high pass. It's currently crossed over using a 24dB/octave filter setting and 80Hz knee. I often play with crossover frequencies. A lower crossover might suit the Revels since they are flat down there but I find I like 80Hz. Playing with this happens if I get bored or get a wild hair. I think the room is the limiting factor. I could use more bass traps/ bass control (or better walls and more rigid floor) but can it get too dry?
I think the main speakers are near optimally placed for wide sound stage while they provide an outstanding stereo image and phantom center channel , best I've ever had by a lot! While the subs might benefit from more creative placement, the speakers will stay where they are for now.
There is a dedicated panel visible just above the TV set in the photo above. It was there when we bought the house because the last owner was into AV. The room is wired for surround and a ceiling mount projector but I don't use that stuff except for the panel. We had two additional 20 Amp circuits installed to go with two existing 15 amp circuits already in the place on the wall behind the rig. Everything is plugged straight into the wall using the OEM power cables. Of course!
There is whole house surge protection which you need here. Lightning and thunder! I have owned (and represented) a lot of gear but never anything nearly as lavish or coordinated as this.
I hope that answers your questions and isn't TMI.
