Yes I have an Okto dac8. I want to stream Amazon Prime Music, do dsp (crossovers and room correction) and out to the dac8.Will an "8-channel" DAC handle a 2-channel music audio signal, yes.
Do you have a DAC that supports 8-channels?
You mean multichannel Atmos? That is not possible. You'll need an AVR/AVP to do that.Yes I have an Okto dac8. I want to stream Amazon Prime Music, do dsp (crossovers and room correction) and out to the dac8.
The DAC will be fed by the software crossover you will use. Streaming tool will feed audio to that software not to the DAC, directly.No, not Atmos. I want to play regular music files from Amazon Prime Music through a dsp program with 6 channels of crossovers, room correction, into the multichannel dac, out to 6 channels of amplification, out to 2 channels of stereo to 3 drivers left and right.
Maybe I should just ask if anyone is using Amazon Prime Music with the 8 channel Octo dac8...
Okto Dac8 Stereo or Dac8 Pro?Yes I have an Okto dac8. I want to stream Amazon Prime Music, do dsp (crossovers and room correction) and out to the dac8.
And what does the manual for the Dac8 say about 8-channel output?
Use J River, point the Amazon Music App at JRiver, then get Dirac Live Multi channel desktop. Install it as a VST 3 Plugin in Jriver. Use the standalone app to measure the 7.1 channels, create your project with the correction curve you desire, import it into the processor residing on JRiver, adjust gain, switch the processor on, and enjoy. Multi channel is around $700, I think. I bought it in segments. Started with 2 channel in 2014, and upgraded to multi channel in 2019.Yes I have an Okto dac8. I want to stream Amazon Prime Music, do dsp (crossovers and room correction) and out to the dac8.
Sure. Depends on your music player app but I've done such (for other reasons) with Roon and JRiver. Other will do it, too.No, not Atmos. I want to play regular music files from Amazon Prime Music through a dsp program with 6 channels of crossovers, room correction, into the multichannel dac, out to 6 channels of amplification, out to 2 channels of stereo to 3 drivers left and right.
