solderdude
K702 pads are angled by 5 degrees.
K712 pads are not angled. This might change imaging.
I often see this on the internet and perhaps the K712 pad is not AS angled as the old K701/K702 pad, but there is one thicker and higher side to it just like the original K701. I have them live so I can confirm, you can also see the slope in this photo:
You can see the thicker, higher side on the right. This would go behind your ear. There's been some reports with K712 headphones arriving with the pads misaligned (pointed up), which has perhaps contributed to people thinking they are completely flat.
You beat me by a few seconds! Same image in the K702 manual (and probably the 701 for that matter).I believe the visuals of that diagram are straight up lifted completely from the K701 diagram. But I have a very early run of K712 and they are angled. It's not an extreme angle but it contours nicely to the back of your head.
Could you please link the article? I've been trying to find the differences between original and third-partyI think it does flatten out a little bit over time but they were angled when I got them. I certainly didn't angle them by wearing them, I don't have that strong a head hahahah. The image above I posted also shows a presumably new pair, it's from an article comparing stock k712 pads and replacement third-party pads.
Thanks for that! I thought it may've had some more comparisons between different types of pads but I'll keep searching!https://www.google.com/amp/s/everyd...01-yaxi-earpads-review-mutual-attraction/amp/
Take it with a grain of salt, I have no idea how reputable that site is
Thanks for that! So just to confirm, are the K712 and K7XX pads the same? I'm pretty sure I recall seeing them as the same on your website.View attachment 109586
L=K712 ... R=K702
The K712 was made in Slovakia, my K7XX was made in China. Pads are the same as K712 from Slovakia so perhaps the pads are made in China ?
Potentially!The K712 (Slovakian) and K7XX (Chinese) pads looked, felt and measured the same.
Chances are Austrian made K712 have/had differently shaped pads ?
The problem with recommending headphones, at least to me, is that what sounds good to me may not be so for others.
A similar thing with comfort.
The differences between the K712 and K702 with K712 pads are small but present.
Personally I liked the K712 (in my case the Slovakian one) a bit better than K7XX.
K702 is not up my alley though but that doesn't mean others can't/won't like it. On the contrary... there are many folks loving it.
The only way to know if you like a headphone is to own one for at least a few weeks. With or without EQ.
A short audition (especially in a store) can set you on the wrong foot. Even when you are experienced.
Something that sounds full and detailed at first glance may become boomy/one-note or sibilant after a while.
Not immediately impressive headphones may sound boring on audition but may sound great once you accustomed to the sound.
So these are the reasons you don't see me rating stuff or telling this or that one is crap or the bomb.
Most headphones have some good and less properties at different loudness levels.
It's just a matter of finding the one that has the most good qualities to the owner.
I can tell you what I like or what is generally liked (and do so) but that may not be what others prefer.
