Gday all
First post..
So many tech details in these threads that Im confused. I have a NAD 777v3. Connected are centre, fronts and surrounds. Fronts and surrounds are basically the same "size"
and same manufacturer. I like listening in stereo when I play music and use the fronts and surrounds together.
If I added a 2 channel amp and connected my fronts to an amp will they be 'louder' than the surrounds (connected to the NAD777
) in stereo or does the NAD777 compensate some how or do I forget about the surrounds and just use the fronts or do I need a amp with more channels?
I was looking at adding a NAD C298 as I assume it should be compatible. I also like the purifi which I have seen on the VTV website and unsure if 'they' would be compatible. If VTV is compatible would I be better off getting a 4 channel purifi.
Another confusing point for me is that the NAD 777 is only RCA. I assume that the NAD C298 would have to work in RCA? Ie NAD to NAD. But its 2 channels.
VTV amps are XLR. I know I can I use XLR to RCA to the NAD777. I mention this as there is lots of threads about voltage to and from regarding RCA. Clipping and 2volts? I thought clipping is when I let the grandkids turn the dial on my avr to 0 and let 1812 overeture cannons blow my speakers tweeters up.
Just wondering will I hear any difference in gain with either a NAD 298 or Purifi type amps.
Im a tad deaf and my lounge room is quite large, hence maybe an amp..but Im confused as and if it is even worth it. Closest HiFi shop is a four hour drive away for me..
Regards
First post..
Regards
