Bryguy
- Joined
- Aug 17, 2023
- Messages
- 122
- Likes
- 159
It depends on how much BSC you implement into the crossover. If none, you can reach basically the manufacturer stated sensitivity, you'll just have weaker bass than you would have on an infinite baffle. The -6dB is just a generalization for how much the bass tends to taper off, and if you want to compensate for that you need to attenuate the rest of the driver's bandwidth equally. Baffle step only really affects lower frequencies. The wavelengths at higher frequencies are small enough that the baffle remains effectively infinite. Some designs incorporate very little BSC into the crossover, and thus preserve the manufacturer stated sensitivity. Most of the times I see speakers with a -3db BSC, and usually only see the full 6dB for speakers with an emphasis on bass. That's just a generalization though. The new Dayton Opal1 for example has close to 6dB BSC (fwiw most folks on the diy forums seem to think it was too much, but that's mostly for IMD reasons. If you plan to use the Sig180 only at lower frequencies then 6dB BSC should be fine, not to mention the sig180 won't play as low as the epique)Oh, that's definitely too high for my desired use. Is that after filtering?
I was under the impression most woofers lose about 6db when tossed on a typical bookshelf baffle but apparently not? I think I'm missing something here.
Btw, this is why it's generally frowned upon to add a woofer to a pre-existing 2 way speaker. The crossover designed for the 2 way will have treated the MW as a woofer, not a midrange.
