No need to remeasure. You misinterpreted the review and measurements. You either don't understand or you are making excuses for a really substandard product. And the stability measurements really do look bad. Sorry you don't wish to believe. I guess it isn't a surprise given how badly Hegel botched nearly every other aspect of the device. Do you really think they are sophisticated enough to do a feed-forward error correction that doesn't actually introduce more instability?
I said that Line Out was driven into clipping so results cannot be interpreted as they were, they are meaningless if amp is clipping. Any device driven into clipping will measure terribly.
Hegel provided their diagram for stability measurement which is without anomalies. That is why I believe there was something wrong with the measurement at ASR. Mistakes happen.
OK, let's say the amp actually gets to 60W, that is anemic. For 2 grand doubly so. But it didn't even do that. You make excuses.
60W can be plenty depending on the size of your room and volumes you are listening at.
Headphone amplifier is bad; 77 Ohm output impedance is a fundamental error of design. Only an idiot would design this. It is fundamentally broken and I'm not sure how you can make an excuse for this. On top of that it has excessive noise, which is a bad thing for headphones. And, 80mW output power is is marginal at best, and becomes absolutely crap with lower impedance phones because you get less power and distorted frequency response.
The headphone amp is nothing to write home about, but such they are on most integrated amps. To Hegel credit, they did not argue with those measurements.
It provides me with basic function I explained already, and without it I would not have bought this device.
Forget the comparisons, the Hegel is an unmitigated disaster. $2000 is a ton of money to spend. I would feel horrible.
Unless a piece you own got a poor review.
No, I like ASR especially when it makes a review of the device I own, good or bad. KEF ls50 got a good review, h95 got bad, so what?
Hegel seems to be snake oil, it is fundamentally flawed in an umber of ways. I am eager to see other Hegel gear reviewed, but hard to imagine that a team of hacks will do better unless the H95 is a one-off basket-case.
You haven't pointed out any mistakes, just made non-technical allusions.
I pointed one obvious and one likely mistake, you just choose to ignore it.
The point of ASR review is to prevent people from purchasing unmitigated disasters, this is a prime example. It doesn't tell me if I should buy a Benchmark or a PuriFi or a Bryston amp, but it does allow me to weed out the unacceptable performers. Hegel is definitely unacceptable. If you have specific instructions on how Amir messed the review up, PM him to address or post specifics in the review thread. None of the complaints that were raised by you or other's in the review were physically or electrically relevant. If I missed a gem, please point me to it.
Your Hegel is simply not an appropriate recommendation. It is the antithesis of what ASR is about, and your arguments are the same.
H95 is not an amazing device but it should be compared against other all-in-ones and none of them measures great. However, there are advantages to owning such a device that just works.
After more than a year of owning it, in my use scenario which is typical for an European apartment-dwelling user, I can say it is not nearly as bad as portrayed here. It sounds good, has no problem driving my ls50 + sub in my living room, can function as stereo or part of multichannel home theatre, it is very stable, simple and convenient to use. I like simple and functional design...
My biggest gripe is missing Tidal Connect but AirPlay functions very well, it is very stable although less efficient.
Who cares if jitter performance is not great if those errors are inaudible.
I would not recommend paying full price for it but if one can buy it used, at good discount, one should not hesitate to go for it. I bet quite a few customers sold their almost new h95 after reading this review.
What is the point in arguing any further? This is not h95 thread, there are 68 pages of arguing already and nothing new can be said.
