With the port sealed, the LS50 Meta will start rolling off at about 100Hz:LS50 should be at 95Hz with the ports sealed? And how can I know the exact hz on the rel?
Yes I read the manual, but whan I conect like this, I have noise all the timeThe Speakon port is REL's preferred way of connecting the T/5x.
Here's what the manual says about connecting Class D Amps:
As the manual says: connect the black wire to an RCA GND somewhere if you have noise.Yes I read the manual, but whan I conect like this, I have noise all the time
Try just touching the black cable on the gold ring surrounding the RCA inputs. If the noise goes away, then you can look into how to connect it there permanently.View attachment 361380so if I understand u correct, I can plug the black cable to the rca on the topping?
ו don't have low level connectionAnyway, I strongly suggest you to connect t5x by low level
It should be kept in mind that also the woofer response changes when the port is sealed so the roll off won't be the same like from such an ported nearfield measurement but usually a bit deeper and with lower steepness so in the end
is the only way to go.For proper subwoofer integration, use a measurement microphone or the HouseCurve App to measure your in-room response, then iterate on crossover and volume knob position until you have a good response.
Correct.It's only apple app? Not for android...
