- Joined
- Mar 1, 2020
- Messages
- 483
- Likes
- 868
I am preparing to buy this AVR and looking at the menu, I am delighted that Onkyo/Integra still has the option to delay trigger jacks. Why Denon and Marantz don't have that option is beyond me.
I don't need it in my room at all, but I run a custom integration company and it's nice to be able to display this type of connection from an AVR to a separate amp. I'll probably throw a 3 channel Hypex or Purifi amp in there to power the L/C/R just for fun (and to demo for clients).It's a pretty "grunty" AVR, you may not need external amps...
The plan is to upgrade to 5.1.4, I guess I can still run 2.0 in zone 2?There are in fact amps for both Zone 2 and 3, though you obviously can't use the full 11-amps for the main zone in this case. However, if you are running a 5.1.2, you can certainly have both zone 2 & 3 amped. Zone 2 and 3 both feature dedicated subwoofer line-outs as well.
Yep that's rightThe plan is to upgrade to 5.1.4, I guess I can still run 2.0 in zone 2?
So.. one amp to rule them all!Yep that's right
3 to be exact, RZ70, LX805 and DRX-8.4So.. one amp to rule them all!
Yes you can!I'm finally due to get my 8.4 today and I'm pumped... can anyone tell me if I can use a umik 1 connected to laptop to configure Dirac?
I found the NAD guide to be useful: https://mehlau.net/audio/dirac-live-2-mic-speaker-levels/Wonderful! Could you point me to a guide that talks me how to do this? Integra's docs say to use supplied mic connected to front panel and an email to Integra has gone unanswered
Thanks so much for that... I'm a newbie to this and there's so much to learn since my pre-HDMI Denon days! LOLI found the NAD guide to be useful: https://mehlau.net/audio/dirac-live-2-mic-speaker-levels/
And I’ve read the entire Dirac Live topic on AVS, whic`h has quite some nice tips: https://www.avsforum.com/threads/dirac-live.3137722
Essentially, you just need to download and install the Dirac Live software on a laptop from https://www.dirac.com/live/downloads/ and then attach the UMIK-1 to your laptop via USB and run the software to calibrate.Wonderful! Could you point me to a guide that talks me how to do this? Integra's docs say to use supplied mic connected to front panel and an email to Integra has gone unanswered
Roon Ready support is supposed to be coming, but it is not here yet. Thus far, I have been using Chromecast through Roon, which streams 2-channel FLAC at up to 24-bit/96 kHz.What about the inputs, can I use the USB port on the back from my Roon NUC endpoint running Rock?
Is there any feedback regarding the internal DAC?
Perhaps I could even skip the NUC and go ethernet directly, I see it's supposed to be Roon Ready.
I see the USB only works for storage, I guess I can't connect it to a streamer. Perhaps HDMI might work..
Have you compared to any external DAC?Roon Ready support is supposed to be coming, but it is not here yet. Thus far, I have been using Chromecast through Roon, which streams 2-channel FLAC at up to 24-bit/96 kHz.
I also run Tidal on an NVIDIA Shield Pro, connected via HDMI, that streams Dolby Atmos music.
No and I wouldn't expect any audible difference from one. The ES9026PRO DACs in the 8.4 are already specced to 110 dB SINAD. The ES9028Q2M in the Bluesound NODE X is only 10 dB better at 120 dB. Amir measured the Denon X3800H at 87 dB, and it sounds fine. I have equipment measuring in the low 70s and it sounds fine.Have you compared to any external DAC?
Can I expect my laptop/Dirac to "see" my new Integra?Essentially, you just need to download and install the Dirac Live software on a laptop from https://www.dirac.com/live/downloads/ and then attach the UMIK-1 to your laptop via USB and run the software to calibrate.
Yes, as long as you have the DRX-8.4 connected via ethernet or WiFi, Dirac will find it on your network and present it to you. You can also check the IP address of the Integra from the front panel (just toggle via the Info button). You can also access the web interface of the Integra by browsing to that IP address and logging in with a username of ciuser and password of ciuser. You can configure the AVR there much faster than going through the on-screen menus.Can I expect my laptop/Dirac to "see" my new Integra?
Great, that's what I was hoping the behavior would be. Thank you all for helping me ;-)Yes, as long as you have the DRX-8.4 connected via ethernet or WiFi, Dirac will find it on your network and present it to you. You can also check the IP address of the Integra from the front panel (just toggle via the Info button). You can also access the web interface of the Integra by browsing to that IP address and logging in with a username of ciuser and password of ciuser. You can configure the AVR there much faster than going through the on-screen menus.
How does it sound in 2ch music? Would I still need keep my Yamaha A-S2100 if I get this you think?
