Killingbeans
Sonos.
Yes, or Ikea Symfonisk.
Sonos.
I have a 1930s house. All the internal walls are brick as well as the external.It may be ready in the future, but for now I am not so sure. I admit that this may depend on construction technologies, as our Dutch homes are not as wireless friendly as US dry wall homes. Our two studies both have wired ethernet for greater reliability and speed and we are still very pleased with that. The bedroom CCA system is wireless and not quite stable - that bedroom is in a far corner of the house and above a heavy steel beam. We also have an extension/garden room where we could only have wireless by first taking it there by ethernet. All these problems are even bigger with the 5 GHz band, while on the 2.4 GHz I compete rather a lot with the neighbours.
Seems like these are mostly free-standing pods. The essential requirement is in-ceiling.Meaning you're looking for wireless?
There are a couple of different options beyond Sonos -- BlueSound / BluOS, the Dynaudio "Music" Series, Apple HomePods, Devialet Phantoms ....what's the price range you're looking to spend and how many rooms?
That’s why I’m thinking no more tubes/wires. All that Ethernet cable is obsolete with WiFi. Same for speakers? New technology is wireless, but is it ready?
Do you have any in-ceiling speaker recommendations?It's ready in my house.
All of our music is over streaming.
The office has a Roon server. There are no physical connections to anything. It's all using mesh networking.
I will have to but it seems fairly expensive for what you get and the Sonos amp did not test well when @amirm looked at it.Check out Sonos in ceiling plus Sonos amp. I think its close to what you're looking for. In addition you get their room correction, its future proof with their evolving upgrades, its a proper architectural solution partnering with Sonance who are a leader in in built audio solutions (eg designed so the grills are paintable to match the ceiling) and it expands to outdoor speaker support
Every time I boot my Windows 10 laptop, Wifi doesn't connect right. I have to disconnect and reconnect to get it going. Broke in one of the Windows updates. In sharp contrast, my workstation with Ethernet works like a charm all the time. So don't skip on Ethernet cable and connection.That’s why I’m thinking no more tubes/wires. All that Ethernet cable is obsolete with WiFi.
Wired or wireless?Do you have any in-ceiling speaker recommendations?
Both would be much appreciated. If the wireless option isn’t reliable, as you indicated it might not be, I’ll need to fall back to the wired options.Wired or wireless?
I had a new house built(never again). I ran all the HiFi cabling and told the builder to let me know when the drywaller got on site. He didn't and the drywaller just went ahead and covered it all in. My protests were met with "it's not written in the contract". Hard lesson learned.
Well, if I am spending $300 per speaker x 8, plus a lot for wiring, it would be a shame for a $600 amp to spoil the sound. So spending more makes sense if that’s what’s required. But I’m not going to spend $1,000 per speaker or $3,000 for an amp.Maybe it would be helpful then to clarify your earlier statement: "Price isn't so much a factor - I want it to sound good, but it won't be for critical listening"
The power for an active speaker comes from mains, just like for a light bulb, but in this case the signal is sent wirelessly.How is any of this wireless? It needs a power cord! And any ceiling between floors will not be accessible, do you really want electronics in there.
Could you link to the 70v option? I’m not familiar with that.
Wireless in the sense that a direct *wired connection to the audio source can be eliminated. Powerwise, wires are obviously still needed, we're not talking about battery powered speakers.
What im saying is, you have to run wires, speaker wires are easier and cheaper than power. You can do it your self, you dont need to hire an electrician. How much are the extra breakers going to cost you?
