Sound on Sound January 2023 issue has a review & test of the new IK Media iLoud Precision MTM active speaker. Full article is behind a paywall, hence I am posting only relevant bits about the effect of MTM configuration. Emphasis is mine.
The above chart is also a good example of how stuffing the vent is not the same as converting the enclosure to a closed box, like many on this forum falsely thinks so.
Here is the front & back view of the speaker along with the measuring microphone.
According to Sound on Sound there are no cons
This is even after the author confirms that "The D’Appolito midrange suck‑out is significant, however. It’s subjectively noticeable and makes the Precision MTM tonal balance a little variable with head position." What do you expect when that "suck-out" is a huge 40dB dip?
Just to remind you that some mute buttons only reduce the level by 20dB. Imagine ten times more reduction than that, right in the vocal range!
Diagram [below] illustrates the Precision MTM axial and 30‑degree vertically off‑axis frequency response, and it provides a textbook example of the power of the D’Appolito format to narrow dispersion through the upper midrange, and similarly how the output of the relatively large tweeter dome falls away off‑axis above about 12kHz. Having pointed that out, I’d suggest it’s of more academic interest (no, really) than subjective significance. The D’Appolito midrange suck‑out is significant, however. It’s subjectively noticeable and makes the Precision MTM tonal balance a little variable with head position. Midrange balance dulls appreciably with head movement away from the central axis, which might sound like an issue — but if you’re aware of the effect, it can be factored in to working practices, and the midrange suck‑out probably reduces desk, floor and ceiling reflections in the critical midband.
Diagram [below] looks somewhat of a jumble, but stay with me and I’ll explain. Each curve represents a frequency response captured with the measuring microphone very close to its specific subject. The green curve is the close‑mic response of one of the Precision MTM bass/mid drivers, and the dip at 40Hz reveals the system’s reflex‑port tuning frequency. The red curve, meanwhile, is the port output captured with the mic at the port mouth. Apart from the port output peaking, as expected from the green curve, at 40Hz, the red curve reveals some output from 500Hz and above that really ought not be present. It appears to be midrange energy ‘leaking’ out through the port, but of course it could potentially be ‘crosstalk’ from the forward output of the bass/mid drivers. So in order to check that, the blue curve was generated by leaving the mic at the port mouth but blocking the port itself (with a duster, now you’ve asked). It confirms that at least some of the output revealed in the red curve, especially the peak at 900Hz and above, is port output, because it’s attenuated when the port is blocked. Stopping midrange energy inside a cabinet from making its way out through the port is a significant challenge in two‑way ported speakers. Using an ABR (auxiliary bass radiator) rather than a simple port can be a solution, as can locating the port in the rear panel of the monitor, as is the case with the Precision MTM, where unintended output is made less troublesome, but port output such as displayed by the Precision MTM will potentially contribute to the subjective character of the monitor.
Pros
- Fine, well‑rounded electro‑acoustic design.
- Great bass.
- Strong stereo imaging.
- X‑Monitor and ARC 3 add some very cool extras.
Cons
- None.
Summary
With the Precision MTM, IK Multimedia’s compact iLoud has grown up to become an extremely capable full‑size nearfield monitor. X‑Monitor and ARC 3 add significant extra capability and appeal.
Information
€2399.98 per pair including VAT.
