Baudrillard_J
- Joined
- Apr 7, 2023
- Messages
- 51
- Likes
- 9
You might be able to audibly live with non-shielded single-ended interconnects for high level line connections such as a DAC to a pre-amp, if you don't have any electrically noisy things in your house and live some distance from transmitters. But for Moving Magnet and especially Moving Coil phono feeds, screened connections are necessary.
Yes indeed and from what I now realize it is not easy to find a good, reasonably-priced pair of phono RCA cables. From what I read "good" means at least a double-braided, 100% coverage copper cable. I am not sure about the actual signal wire, if it is considered best practice to be single core or braided, most implementations of "high-end" phono cable seem to use a braided signal wire (not counting the braid which acts as the return path or ground for the single-ended signal not the external turntable ground). From a brief search online, these cables run upwards of $500 and can reach up to ~$10.000 for the Fono Acustica Armonico Phono. And no, this is not an ad feel free to post an even more expensive one if you find it. Maybe then we can get @amirm to test it!
Now, it seems to me that many choose to make their own phono cable using good quality microphone cable and rca plugs of their choosing. For that case, my understanding is that you care about the capacitance of the cable only for the case of a MM cartridge and that for the MC case your goal is to keep the resistance as low as possible. As for inductance, in my case of the MC-Low DL-103 into what @Thorsten Loesch recommends as proper loading of 1KOhm (which is what the Zen phono presents to the cartridge at the MC-Low input) any cable inductance effects are already taken care of by that 1KOhm input resistance. Again, this is from what I read online.
I am also sharing here for reference two photos of the Zen phono (internal) PCB. It seems that it is using the STC 12LE5A60S2 microcontroller and OVA2637 opamps for which there are no spec sheets since it's in-house.
