I Need To Find A Cheap DAC
Platypus20
Syracuse, NY
Today, I gave my late wife’s stereo receiver and cd changer to my daughter. The receiver is a Marantz stereo receiver from the early 2010s, works perfectly, no digital inputs. She has a TV with no analog sound outputs, just a solitary Toslink outlet. So I now need a small cheap DAC to convert her Toslink to a usable analog signal. I want it as simple as possible, no volume control, just a simple box. Any suggestions ??
Platypus20
Platypus20
Syracuse, NY
Thank you, I looked on Amazon and saw nothing under $65, her cable service supports Spotify. So she would like to send the audio from the TV to the stereo. Again thank you, I’ll get it on order.
Roland68
Cologne, Germany
Amazon, Aliexpress, Ebay etc. simply have DACs that convert Toslink to RCA. Costs about $10-$40.
Matias
São Paulo, Brazil
DonR
Vancouver(ish)
Here is a review of the AmazonBasics one which is the same DAC really. https://www.audiosciencereview.com/.../amazon-basics-optical-coax-dac-review.30339/
Not recommended and has a few issues but should be perfectly fine for the non-audiophile (i.e. 99% of people).
Platypus20
Platypus20
Syracuse, NY
Exactly, the daughter is looking for sound from the tv through the stereo, anything above 2 soup cans and a taut string quality, should be more than adequate for her purposes.
Platypus20
Platypus20
Syracuse, NY
That sounds a bit perplexing to me.
Anyway, I’d consider the S.M.S.L SU-1.
Whats perplexing ?? A tv with a set of RCA (dvd), 2 HDMI and a 75 ohm cable inputs, the only output is a single Toslink output for the remote audio signal
the $20 unit (with shipping) should work for her needs
DonR
Vancouver(ish)
My son's Samsung has no analogue audio out in either RCA or headphone form. It seems to be becoming quite common. Good way to upsell to an eARC capable soundbar, I think.
Golf
OK – seems I’m not up to date. My TV set is about 10 years old :)
Platypus20
Platypus20
Syracuse, NY
Yep, no issues, it make no sense, but as DonR said probably to get you to do their upgrade at a future date
daughter is an iPod/iPhone user, through a speaker that looks like a mesh tube, the old stereo will do her fine.
mhardy6647
A mesh tube?!?
Platypus20
Platypus20
Syracuse, NY
I went to the daughters house, installed the optical cable, DAC and interconnects, worked perfectly, there is now TV audio, going to the Marantz receiver, the daughter is thrilled
