What sort of issues would that cause?
The power supply will not be able to maintain sufficient voltage resulting in output dropping. Keep in mind an amplifier should act as a perfect voltage source. The amperage required at any voltage is a function of impedance. Half the impedance and double the ampage requirement for a set voltage. It is Ohm's law. The way that most engineers think about it is not to think in watts, but volts. So for the Purufi, it puts out about 42.5 volts. If it had unlimited current capability, it would put out the following outputs:
8 ohms- 225 watts
4 ohms- 450 watts
2 ohms- 900 watts
1 ohm- 1800 watts
Current at these levels would be:
8 ohms- 5.3 amps
4 ohms- 10.6 amps
2 ohms- 21.2 amps
1 ohm- 42.4 amps
The thing is that the Purifi doesn't have unlimited current capability, NO AMPLIFIER DOES. Purifi rates their amplifier to less than 2 ohms with the caveat that "[t]he amplifier is stable into loads <2 ohms. Output power may be limited by the Over Current Protection system." At 2 ohms they also provide that the amp puts out 450 watts "as limited by thermal system". If you take their rated output spec at 2 ohms, it suggests the maximum current the amplifier can supply is 15 amps. At 450 watts into 2 ohms (Purifi's rated output), voltage has dropped to 30 volts. At 1.5 ohms, this means maximum voltage will drop to 22.5 volts and 337.5 watts output.
Now lets bridge two channels. Voltage doubles, impedance seen by the amplifier is 1/2, and current capability is the sum of the two amplifiers (so 30 amps) (correction, I said before voltage was the same, it doubles). So now with a 85 volt maximum voltage and unlimited current the numbers are:
8 ohms (4 ohms seen by the amplifier)- 900 watts
4 ohms (2 ohms seen by the amplifier)- 1800 watts
2 ohms (1 ohms seen by the amplifier)- 3600 watts
1 ohm (.5 ohms seen by the amplifier)- 7200 watts
8 ohms (4 ohms seen by the amplifier)- 21.2 amps
4 ohms (2 ohms seen by the amplifier)- 42.4 amps
2 ohms (1 ohms seen by the amplifier)- 84.8 amps
1 ohm (.5 ohms seen by the amplifier) - 169.6 amps
But we don't have unlimited current capability. We have 30 amps and that is subject to heat dissipation ability. So bridged the Purifi numbers look like:
4 ohms (2 ohms seen by the amplifier)- 1700 watts
2 ohms (1 ohms seen by the amplifier)- 1800 watts (current limited)
1 ohm (.5 ohms seen by the amplifier)- 900 watts (current limited)
8 ohms (4 ohms seen by the amplifier)- 10.6 amps
4 ohms (2 ohms seen by the amplifier)- 21.2 amps
2 ohms (1 ohms seen by the amplifier)- 30.0 amps
1 ohm (.5 ohms seen by the amplifier) - 30.0 amps
Because of the limited heat dissipation, when bridging, you will be running closer to the thermal limits and maximum capability of the amplifier more often. It is likely the maximum output at low impedance will be less than my calculations. Bridging also normally doubles distortion and in general amplifiers generate more distortion at lower impedance. THIS IS NOT UNIQUE TO PURIFI, IT APPLIES TO ALL AMPLIFIERS. Given the foregoing, it is generally not the best idea to run bridged amplifiers into low impedance loads and why amplifiers that are rated into 4 ohms loads are rated only down to 8 ohms when bridged.
It is important to note, this is my understanding based on my limited knowledge. I may well be wrong and encourage anyone with more knowledge to correct any mistakes.
https://en.wikipedia.org/wiki/Bridg...nected between,most often used for subwoofers.
