OTOH, more watts does not always mean more available current at a given instant in a musical/theatrical passage. And of course there are other factors to consider, how ‘quiet’ the amp is, how fast the circuitry can adapt to changing input voltages,etc.
Be careful falling into this trap, an amplifier only supplies as much current as necessary to maintain the voltage it is supplying. Take for example 100 watts into 8 ohms. This is 28.28v at 3.53 amps. It doesn't matter whether your amp can supply 5 amps of current or 100 amps of current, it will only supply 3.53 amps. If it can't supply 3.53, current becomes the limiter and voltage will sag, decreasing wattage. (I am ignoring phase angle which can change this a bit).
So looking at the hypex and purifi amps, the NC1200 and 1et400 both have plenty of current capability to maintain their power into any reasonable load. In the case of the NC1200 it has 38a of current capability. Running it's power calculations we come up with:
8 ohm @ 400 watts = 56.5v and 7.07 amps;
4ohm @ 700 watts = 52.9 v and 13.22 amps;
2 ohm @ 1200 watts= 49 v and 24.5 amps.
You are not running out of current even into a two ohm load. You will see that voltage sags a bit, a perfect amplifier would not, but there are very few, if any amplifiers that don't have some voltage sag at the rails into lower impedances.
Taking the Purufi 1et400 module, it is capable of 25 amps and notes that the "amplifier is stable into loads <2 ohms. Output power into impedances <3.2 ohms may be limited by the Over Current Protection system." Taking the numbers:
8 ohm @ 227 watts = 42.6 v and 5.32 amps
4 ohm @ 425 watts = 41.2v and 10.3 amps
2 ohm @ 450 watts = 30v and 15 amps.
So with the Purifi we see that when we get down to 2 ohms, it did what the manufacture said, it limited the current to 15 amp and the voltage dropped. If we calculate output at 3.2 amps, assuming we are still at a 41v rail voltage, we get 12.8 amps of current and 525 watts.
So here is the really important thing, these numbers only apply with the amps are right up against their clipping point. At anything less voltage and in turn amp requirements drop a great deal.
As far as how quiet both amps are, they are both well below the level you will ever hear, at least 110db. The only difference is that one amp will give you an additional 3-4db of sound output capability over the other.
