- Joined
- Dec 29, 2020
- Messages
- 73
- Likes
- 34
I've gone through two Hypex NC252 amplifiers in two years. The first unit failed after 10 months, and was replaced under warranty. The second failed after 12 months; it's now out of warranty.
The failure mode was the same for both units: The left channel dropped to five or ten percent power (relative to the right channel), and the sound content was half music and half fuzzy static. Normal operation returned after some hours with power off, and stayed normal for a few days. The second unit has gotten to the point that it will not hold full power on left channel for more than a half hour or so, and the right channel has been also been putting out fuzzy static (though right channel power is not diminished).
It may be that the case does not provide enough ventilation. It's a small Ghent case; the top sheet is perforated with small holes. With the first unit, the case felt warm to the touch (but not hot), even after sitting all night with no input and a low volume setting. With the second unit, I left the front plate off the case to improve ventilation. But the power devices are at the back of the case, and I don't know for sure what the temperature may have been at the heat sink. (The assembled amplifier was purchased from a reputable vendor. When the first NC252 failed I removed it and sent it to the vendor. I installed the second unit into the case myself, but did not disturb the wiring.)
I really like the sound from the Hypex. I have had an Onkyo tuner/amplifier for 25 years, which I bought for its low THD spec; it was a great improvement over the stereos I had previously owned. Hearing the Hypex for the first time I felt the same way: much better sound quality. Listening with eyes closed, I am often surprised just a little bit when I open my eyes and do not see the performers in front of me.
For reference, the other components in the system are a miniDSP SHD, LS50 Metas, and Rythmik servo woofers. The SHD is set to USB input 99% of the time. Since installation of sound absorbing panels, I have kept Dirac turned off.
I have two questions.
1. Has anyone else had problems with the Hypex 252? (I've seen the photos on this forum showing the gap between power device and heat sink. I'm wondering if anyone has seen actual failures, perhaps due to that cause. Admittedly, I did not go back to that long post today to read the latest entries, since I have a second question anyway.)
2. Are there any recommendations for other amplifiers that will provide the same quality of sound at 250 watts per channel rating? (I don't necessarily care if it's a D class amplifier; I just want good sound.)
