Suggestions needed - Compact power amplifier?
BergeHiFi
Hello all people of this forum.
I need suggestions for compact power amplifiers.
It needs to have:
  • Balanced input via XLR
  • Less than 20cm depth (that is 8 inches in freedom eagle)
  • Not too tall, but width is not any issue.
  • 2 og 1 channel, so both stereo and monoblocks are good
  • As good sound quality as possible.
  • Internal PSU (Edited in after first answer)
Do you have any suggestions?
GaryY
Maybe this one?
B
BergeHiFi
Maybe this one?
Thank you for the suggestion. :D
I have added another requirement - Internal power supply. :)
I would also like it to be a bit better than Fosi.
GaryY
I see. Many of audiophonics class D amps are 22cm depth. A little bigger than your needs.
olieb
That is probably "better" of the inaudible kind, but maybe the TPA3255 sibling with PFFB from Aiyima is interesting, it's not yet fully there though. and it is a bit on the tall side, you did not specify what is your limit.
EDIT: Aahh - power not included ;-(
JeremyFife
Scotland
Audiophonics do a range of amps in a compact case; long and thin (141 x 357 x 65 mm) ... turn them sideways?
JSmith
Algol Perseus
Unsure about depth;
JSmith
GaryY
Unsure about depth;
JSmith
I found this in Ali.
B
BergeHiFi
Thank you all for the suggestions! :D My list is growing.
Any suggestions for DIY cabinets that might fit a Purifi amplifier inside?
