Hah! The update for TIDAL, version 2.73, has just been released this morning by Google Play Store here in the UK. Been checking daily.
Ok guys, what I am looking to do is maximise the audio quality in my car - bit rate and bit depth - as I understand Android Auto can mess with the sound.
Basically I have been using my Samsung S21 Ultra phone to play Offline (Downloaded) TIDAL Music via the TIDAL app through a small Hidizs S3 Pro DAC plugged into it and then taking an Auxiliary lead from it to an Auxiliary socket in my car. This feeds my 2017 Audi's Bose Head Unit and I do experience good quality music this way. However I do not have any Art Work or Navigational Controls on the car's display or via the steering wheel buttons and don't think connecting up this way could be made to work through Android Auto.
The other week I learned a bit about Android Auto and much to my amazement I found that it was available in my car. So I connected up using a USB cable from my phone to a USB socket in my car and it works via TIDAL! But I feel the music quality is not as good as before. So I then wondered about using UAPP a program I use extensively in the home, so I am very familiar with it. I soon learned that UAPP could not use its TIDAL interface for playing back Offline (Downloaded) music - it doesn't have this function - it can only play using a WiFi or a Cellular Data connection. I tried but had to get hold of AnyAutoAudio via the XDA form first so UAPP can be made available through Android Auto. I get reasonable results when the car is parked up at home (where I do most of my testing) as it connects somehow but not sure what connection it is using. Sometimes I experience drop outs. But on the road it's hopeless completely, never mind drop outs but going quiet for minutes at a time and coming back on.
I don't know if these issues are down to the multitude of connections I make available, UAPP or Android Auto, but when it works sound quality seems ok but I cannot be sure what bit rate and bit depth it's pushing out. I'm going to experiment using a small hub so I can connect the phone and UAPP as before via USB but playing back locally some of my Hi-Res music stored on a Micro SD Card.
What do you guys think? - and then there's Bluetooth lol! I have absolutely no idea if my Head Unit supports LDAC or not, but I tend to leave it on, along with WiFi and Cellular Data.
But essentially I'd like to play my TIDAL music via UAPP through Android Auto if at all possible with Android Auto not messing with the bit rate or bit depth. To compare with using my Hidizs S3 Pro DAC, mentioned in the different setup earlier.
Any help and advice would be extremely useful. Thank you
