high level subwoofer connection vs. rca
hawk01
south of the equator!
hello all,
there has been a mixed bag of information as to the merits of having a high level subwoofer connection as recommended by REL versus the typical low level rca connection similar to the LFE channel of most AVRs and pre-outs or sub-outs of some integrated amplifiers.
@amirm has been particular about using low level. i would like to get a more thorough explanation on the whys and hows behind the merits of using low level against high level in order to clear the brewing cloud of confusion.
everyone’s insight hopefully @amirm would be most appreciated!
cheers!
March Audio
Albany Western Australia
Hi level will have more noise and distortion. Its going through an additional and unnecessary amplification stage. REL are absolutely wrong on this one.
If you are using an AVR it will also filter the low frequencies (typically @80Hz) and send them to the sub. Your mains will have less distortion not having to play those lowest frequencies.
Chrispy
PNW
Rel is just strange. I wouldn't ever buy one of their subs let alone their connection recommendations. A shame, really.
H
hawk01
hmm, so it appears my humble yamaha avr is doing a better job at delivering quality bass compared to the REL?
here’s my dilemma, i have a marantz integrated which should be better at doing 2ch stereo but it does not have a sub-out or pre-out. by the looks of it i may be doomed to go the high level path in order to connect with my dual svs sb1000 which fortunately has both high level and rca connections.
Chrispy
PNW
Your typical avr has superior bass management, most integrated amps have primitive 2ch tech. Some subs can handle a stereo input and even provide a high pass for your speakers but most subs merely have a low pass filter labeled "crossover".
I'd stick to line level inputs when possible, particularly with bass management before that point.
H
hawk01
although in fairness to my humble yamaha avr it does a wonderful job of integrating the mains with the dual subs for 2ch stereo listening. whatever shortcomings and potential poor measurements it may have due to the cocktail of noise brewing inside is not audible for me to discern...
Chrispy
PNW
Noise brewing inside?
H
hawk01
not audible noise. guess i am just being too prejudice in using my yamaha avr for stereo use due to its cluttered nature of too many things inside like dsp, etc. unlike my marantz integrated which is a purely analog amplifier. sounds really great compared to the yamaha even when its in direct mode. it only fell short not having any form of bass management.
H
hawk01
your inputs above are a significant wealth of affirmation! i tried hooking the svs sb1000 speaker level to the marantz integrated. there is bass but i just hear something is so amiss with everything. on the other hand, the sub out from yamaha avr crossed at 80hz sounds properly integrated, very cohesive.
H
hawk01
a follow up to all this: will i get equal or better performance with an avr bass management using an integrated amplifier with subwoofer or pre-outs? of course after tweaking the gain and crossover settings...
Chrispy
PNW
Difference in better bass management, which the Marantz integrated likely has none of....
Chrispy
PNW
This sounds like the idiocy resulting from most audio magazines/blogs....
Chrispy
PNW
ah yes and i the unwitting victim of said idiocy which i bit hook, line and sinker! if not for the more informed folks here i would still be diving deep into the rabbit hole of false information.
This and a relatively few other places are the way to go......but then again measurements aren't going to dictate preferences....
H
hawk01
on the other hand, will an integrated amplifier equipped with proper sub-outs or pre-outs perform well like an avr’s bass management after tweaking the crossover, gain settings etc?
Chrispy
PNW
What do you mean by "proper sub outs or pre-outs"? You don't seem to understand the circumstances generally....
H
hawk01
to that i took a leap of faith! bought myself the elac dbr62 solely based on its merits here in ASR. and voila! it is really an amazing speaker! you only realize what you do not hear unless you listen to something that tells you otherwise! not to bad mouth the fullrange drivers i have, i suddenly discover their faults and shortcomings as a speaker when the elacs began singing in my dedicated listening room.
Chrispy
PNW
integrated amplifiers with a subwoofer out rca connection. like the yamaha as701, nad326bee, and the like.
So please demonstrate the abilities of these particular units in equivalent terms......thanks in advance.
