- Thread Starter
- #541
Not to a human.Firstly, this shows the weakness of the FR measurements you make to evaluate the headphones, if they change by one milimeter.
Unfortunately I don't. I'm sure there are a handful out there though - let me know if you find some. Part of the issue is that the option of applying different filters to each channel separately (left, right, stereo, mid, and side) is typically not part of free effects (I don't think MFreeformPhase lets you). E.g. I use fabfilter's Pro-Q for the width trick I mention, but annoyingly there is no all-pass filter available in Pro-Q - you'd have to go to their Volcano for it. So you'd likely need to split the signals into 2 (one L and one R), send them to differently-configured effects, them combine them again.Nice, I will look into using some VST with APO to mess with phase. Do you know more free (or cheap) VST plugins that can do that besides MFreeformPhase?
Headphones are most of the time min phase systems. They take EQ well. As long as the driver has low distortion and exhibits min phase behavior(no cancellations in the response for example), they can be EQ'd easily.Exact same output between two headphones through the designed filter for the same given input.
I think it's also important to note that there is another option: if the cheaper option that adheres to the target FR (e.g. Harman) is also tunable without distortion, then you could add EQ to match your preferred target* and save money.
C:\Program Files\EqualizerAPO\config
phase.txt
with contentInclude: phase_left.txt
Include: phase_right.txt
phase_right.txt
with contentChannel: L
Filter: ON AP Fc 290 Hz Q 2
Filter: ON AP Fc 590 Hz Q 2
Filter: ON AP Fc 1000 Hz Q 2
phase_left.txt
with contentChannel: R
Filter: ON AP Fc 250 Hz Q 2
Filter: ON AP Fc 520 Hz Q 2
Filter: ON AP Fc 900 Hz Q 2
phase.txt
in the text box thereI have always had a question, why can't all three low-frequency preferences of the Harman curve be displayed in the chart?No one is aiming to model a headphone. We are trying to estimate its tonality and we can do so with high level of success. Indeed a lot of Harman research was performed by using a surrogate headphone to emulate the frequency response of other headphones. Before running with this, they verified the efficacy of the method:
As you see, the surrogate headphone equalized to the real headphone's response produced statistically even preference from listeners in controlled tests.
So both in theory and matter of actual testing, your assumption is wrong here.
Beyond tonality, the problem gets hard but tonality is so important and fundamental to headphone performance.
Absolutely. You can't, however, turn it off, and that's important to keep in mind. Let's say a new song comes out, and the artist has taken deliberate time and effort to make the high frequencies shift about in a pleasing way (in more specific terms, passing this song through a goniometer https://en.wikipedia.org/wiki/Goniometer_(audio) will show a width greater than a full hard pan left or right, and that width changes/shifts over time). This headphone, with its current response, will interact with that careful effort and may sound worse (assumption: susvara has variable phase changes in the higher range).Best part is I can use any source and get all that non high fidelity tweaks without being tied to a specific hardware, specific OS and specific software.
Because we want to have a single standard. Multiple standards is an oxymoron. From the research paper on this:I have always had a question, why can't all three low-frequency preferences of the Harman curve be displayed in the chart?
Amir chooses not to for his own reasons, it does not mean it can not be done. There are a few places that do show the natural variation in preference found in the study as boundaries.I have always had a question, why can't all three low-frequency preferences of the Harman curve be displayed in the chart?
“For his own reasons”?? Amir use the curve that the research recommended, period, why to graph the outliners?, and can anybody explain the rest of the comment, it did not make any sense to me as many of his previous comments, it’s becoming so tiresome.Amir chooses not to for his own reasons, it does not mean it can not be done. There are a few places that do show the natural variation in preference found in the study as boundaries.
I was, and still am to an extent, proponent of the idea to show the preference variations not for bass only but for the overall range. One fair criticism of this approach however is that if you were to pick a high bass low treble option for yourself for example, you will still be within the "boundaries" of preference deviation, but you would have tilted the balance in one direction so much that the overall spectral balance would be too far away from "neutral".
And if you do if for bass only, you have the same problem. There is this perception that the way to achieve more spectral balance is to fill in as many holes in the FR graph as you can. That is not correct. If you add a bass boost to an already bass tilted headphone (e.g. due to holes in treble), you'd actually be moving it away from balance, not close to it.
The rest of the comment explains the point I have made to him: that if you put a band around the target, a headphone could be in that gray area in bass at the peak, and lowest in treble. This is wrong as the bass response was associated with a certain treble response, not independent of it.“For his own reasons”?? Amir use the curve that the research recommended, period, why to graph the outliners?, and can anybody explain the rest of the comment, it did not make any sense to me as many of his previous comments, it’s becoming so tiresome.
You did indeed, and you were right.The rest of the comment explains the point I have made to him: that if you put a band around the target, a headphone could be in that gray area in bass at the peak, and lowest in treble. This is wrong as the bass response was associated with a certain treble response, not independent of it.
Just test tones and sweeps here mate.you must be kidding...
this forum must be something like the Truman Show, you really can't be people listening to music
What kind of music do you listen to?you must be kidding...
Seeing how crazy wrong it is to say another audiophile doesn't listen to music, we know how much you value reality.you must be kidding...
